Hi, I got a Fmi and I need some help on the best way to fit it?
The pipe work I'm sure I can handle, as I know where 2 go haha so I will guess the rest lol
What I need help with is where does the bracket work for the core go and will I need to drill holes to fit them? Any pictures would be greatly appreciated
Thanks
A810F417-0AB1-416B-863B-6FC9DB379868_zps
  • Replies 55
  • Created
  • Last Reply
Top Posters In This Topic
Fitted the same kit to mine.
To get it sitting perfect your need to cut abit of the bar that runs from the bonnet catch to the bottom sub frame. This allows the core to slide up behind the crash bar. as it's a bjg core without doing this it'll hang out below the bumper like mine did. See my build thread for reference mate pics there.
It supports the bonnet latch.
No, just the bit that's sticking towards the front of the car, this will allow it to slide up behind the crash bar meaning it won't hang out like mine did after fitting, then drill a hole and bolt it on, or reuse the lower bonnet latch bolt.
Mine didn't fit without doing the above, but yours could be different, I doubt it though!
well come on man I said little trimming to no cutting...
easy take the crash bar of completey.. the core bolts on with brackets to the chasis and its done like this
simple
204808_10150582332950241_823900240_18230
Edited by iamlegend
Also there is a long pipe in the box with a bracket sticking onto the side of it ? Where does that bolt onto ? And if I take the crash bar off I don't need to cut that support and it will fit behind the standard bumper ?
Yeah if you do it legends way. But your severely regret it if you had a small bump. Would ruin the core and turbo behind it as the core would take the hit not your bar... Entirely up to you how you fit it! There's no right an wrong!
The pipe that has the bracket will be the cold side pipe, it bolts onto a little hole just underneath the battery tray, im doing mine atm just in for a heat but dont take the crash bar out imo its a safety feature mate albeit not the biggest but it will take a bit of a bump at least
Upto you though if the weather wasnt so shite i would of popped down and showed you
Ok dude ! And is there a hole at the battery tray for it or will I need to drill ? Where you from
Mate ? My old car never had a crash bar so might just pull it out
Glasgow mate , looking at your kit has puzzled me as my old kit te bracket was sort of twisted and im
Sure the hole was there it was years ago man , tbh mate if you wanna pull it out just whip it out , ill end up becoming a hippocruit
And doing the same with mine if i get fed up haha
