Can anyone shine some light on this situation as it's not coming from the sunroof baca use my seat would be wet and whims te dash is dry also it's just odd that only the drivers floor is wet and nothing else and no holes underneath please anyone am sick of driving too work in a paddling pool :-(
  • 2 weeks later...
Has anybody got any info on changing the heater matrix mines leaking in ps :( on the bonus I have no carpets so I clean it up straight away haha must be the matrix, I have heard it's quite a job! Are the exspensive to buy or is it best to just flush the matrix out? What you's reckon?
Is it the same kinda process for ep91? Stinks of coolant in my car and rads empty
Must be the heater matrix, I'm not going to use mine for a while not arsed about being cold lol
A lad told me to try rad weld in it..
Cant see why iy wouldnt work..
But as i was saying to him, put it in the inlet pipe for matrix at the fire wall..
His mate did it that way and its still good after 2 years
Good idea :) which pipe is the inlet pipe I havn't looked at them properly yet
I bought some rad weld today which pipe should it be put in anyone? will it need the full 250ml really don't want to take the dash off lol
Im nearly sure its the left handside one on the bulk head mate..
Dont think it would make much of a diffrence which pipe to be honest..
Let me know how you get on.. Was your matrix leaking bad?
I chucked a bottle of k seal in and it seems to have sorted it, ill put it directly into the matrix if it starts to leak again
Whats k seal mate?
Its rad weld buddy, ive used it before to seal a leaky rad, it worked then and it seems to have done the trick on the matrix too
Have you looked up under the dash to see is it leaking at all??
Let the car get to half way on the temp gauge and see does it drip..
Good job mate..
Did you just put it directly into the matrix rad?
Pitty i started to take the dash out before i seen this thread..:)
