Tha Dragon Posted January 20, 2014 Share Posted January 20, 2014 Hi guy's I have just installed HDI FMIC installed and everything but i have boosting issues before i installed it i was boosting 1.23bar with a greddy bov, i checked everything out for leakes but did not find any, so now i went for a spin stepped on the gas for a test drive suddenly my car is boosting only 0.53bar. Can someone help me out here on what could be the problem? Quote Link to post Share on other sites
Zeldoz Posted January 20, 2014 Share Posted January 20, 2014 Check all the piping for a loose clamp, also 1.23bar, are you forged otherwise that's a dangerous number to boosting at! Quote Link to post Share on other sites
Tha Dragon Posted January 20, 2014 Author Share Posted January 20, 2014 (edited) I did check all the piping no leaks, mods: racing airfilter, Fpr, Walbro fuelpump, gizzmo ebc, uprated actuator, HDI FMIC, Stock turbo, greddy Bov and for some strange reason it's blowing off in the intake pipe where the racing airfilter is located, bov doesn't even move a bitFuture upgrades:stand alone ecu,full forged kit,330 injectors,TD04 or TD05 turbo kit.did i forget something? What could be the problem that i'm not boosting could it be that need 2 tighten the actuator a bit more or could the bov be leaking?Please help me out here Edited January 20, 2014 by Tha Dragon Quote Link to post Share on other sites
H_D Posted January 20, 2014 Share Posted January 20, 2014 your car should be hitting fuel cut way before 1 bar. are you running a FCD or aftermarket ECU? Quote Link to post Share on other sites
Tha Dragon Posted January 20, 2014 Author Share Posted January 20, 2014 Gizzmo EBC comes with FCD on it. Quote Link to post Share on other sites
pick1 Posted January 20, 2014 Share Posted January 20, 2014 Case of process of illumination check all front mount pipes and connectors , check vac pics and cracks or leakage check blow off valve for leakage your deffo loosing pressure somewhere can u hear a whistling from anywhere ?? Quote Link to post Share on other sites
Tha Dragon Posted January 20, 2014 Author Share Posted January 20, 2014 I thought i heard it yesterday when i tried it again but difficult 2 hear it with a free flow exhaust pipe and with an aftermarket muffler on it but imma try putting it on a dock or some while up i'll step on the gas and c if i can hear or see the leakage cause 2 weeks ago i received the FMIC so it's not used but imma try that and let u guys know cause i'm all out of options here Quote Link to post Share on other sites
fremyjay Posted January 20, 2014 Share Posted January 20, 2014 I had a similar problem once, try tightening the pipes abit more, I swore mine were all tight and not leaking but after another round of tightening them all up it was fine Quote Link to post Share on other sites
Tha Dragon Posted January 20, 2014 Author Share Posted January 20, 2014 Ok gonna try it out as soon as possible i'll keep you guys posted and thanks for the info. I will be asking allot cause where i am from there isn't allot of info about these cars that's why i joined the forum so i can get some help and with that i can help out where i live. thanks guys Quote Link to post Share on other sites
Eynonz Posted January 20, 2014 Share Posted January 20, 2014 (edited) I've got a leak too, going to try this on the weekend to see if it makes it easier. >http://www.youtube.com/watch?v=b3KmQenhWDY Edited January 20, 2014 by Eynonz Quote Link to post Share on other sites
Tha Dragon Posted January 20, 2014 Author Share Posted January 20, 2014 Thanks EynonzGonna try it today Quote Link to post Share on other sites
Mikeyallgood85 Posted January 20, 2014 Share Posted January 20, 2014 I've got a leak too, going to try this on the weekend to see if it makes it easier. good video dude, you can't always see or hear a boost leak and soapy water is the best way :-) Quote Link to post Share on other sites
Tha Dragon Posted January 20, 2014 Author Share Posted January 20, 2014 yEAH THANKS I'LL KEEP YOU GUYS POSTED Quote Link to post Share on other sites
mikey4410 Posted January 20, 2014 Share Posted January 20, 2014 Can only b a boost leak.if all was fine before it has to be that.lol Quote Link to post Share on other sites
Tha Dragon Posted January 21, 2014 Author Share Posted January 21, 2014 Hi guy'sDid everything u adviced but everything is ok, noticed that the bov isn't getting any pressure to open it i think that's why it is stuttering in the intake pipe, but if i have an internal adjustable actuator installed should i close it up a bit or leave it like that cause i was thinking cause of the TMIC need little pressure to fill it up i am thinking that i need to close it a bit cause the way from turbo to intake manifold got bigger, just a thought cause i don't know anymore what 2 do cause it's weirdBuy i really want to know what the problem is Quote Link to post Share on other sites
pick1 Posted January 22, 2014 Share Posted January 22, 2014 Check your actuator isn't sticking that can cause it not to reach full pressure psi aswel Quote Link to post Share on other sites
