Zeldoz Posted January 27, 2014 Share Posted January 27, 2014 Newly installed 6puk clutch, unsprung and clutch release bearing.. fitted 300km's ago. If you rev the car in neutral gets about 2k, you hear almost a grinding noise coming from the box.. If you depress the clutch and leave it in nuetral and rev the car, the noise isn't heard. Someone said clutch release bearing, but it's brand new?... Confused, annoyed.. 3 hours pulling the box out last week to happen all over again by the looks of it. It sounds horrendous, and last maybe 3-5 seconds sometimes considerably longer. Can get a video this evening. Quote Link to post Share on other sites
Zeldoz Posted January 27, 2014 Author Share Posted January 27, 2014 Bump for a poorly box Quote Link to post Share on other sites
mikey4410 Posted January 27, 2014 Share Posted January 27, 2014 clutch realise bearing Quote Link to post Share on other sites
Zeldoz Posted January 27, 2014 Author Share Posted January 27, 2014 (edited) clutch realise bearing It was brand new, and it is basically what i think it is.. Can they be faulty out the box? (NEW) Edited January 27, 2014 by Zeldoz Quote Link to post Share on other sites
mikey4410 Posted January 27, 2014 Share Posted January 27, 2014 defo that man.yeap its heard of for sure Quote Link to post Share on other sites
Socks Posted January 27, 2014 Share Posted January 27, 2014 Seen this sooo many times now... I wouldn't use ANY other release bearing bar one that says Toyota on it... There all shite! Even if you re-use and re-grease an old Toyota one its better then the new shite that comes with aftermarket clutchs these days... Quote Link to post Share on other sites
Adam-Gt- Posted January 27, 2014 Share Posted January 27, 2014 Hate to say it mate but ....... I told you so What a bummer id do it for you but don't fancy taking the gearbox out Quote Link to post Share on other sites
Zeldoz Posted January 27, 2014 Author Share Posted January 27, 2014 Seen this sooo many times now...I wouldn't use ANY other release bearing bar one that says Toyota on it...There all shite! Even if you re-use and re-grease an old Toyota one its better then the new shite that comes with aftermarket clutchs these days... Could i reuse my old one? Still have it sat in the box? - If no, what's the cost of a new toyota release bearing? Fucking fuming. £350 for a clutch to get this 4 days after fitting!!!!!!! Quote Link to post Share on other sites
Socks Posted January 27, 2014 Share Posted January 27, 2014 If your old one isn't fucked and is genuine Toyota... Of course you can, its what id recommend... Quote Link to post Share on other sites
Zeldoz Posted January 27, 2014 Author Share Posted January 27, 2014 If your old one isn't fucked... Of course you can, its what id recommend... How can i tell? Sorry to sound like a numpty. Quote Link to post Share on other sites
corofin12345 Posted January 27, 2014 Share Posted January 27, 2014 cheapish release bearings never last with paddle clutches.. id change it asap cause it could damage the pressure plate.. same happened me, paddle clutch with cheap release bearing.. it destroyed the pressure plate and disc for a finish Quote Link to post Share on other sites
Zeldoz Posted January 27, 2014 Author Share Posted January 27, 2014 cheapish release bearings never last with paddle clutches.. id change it asap cause it could damage the pressure plate.. same happened me, paddle clutch with cheap release bearing.. it destroyed the pressure plate and disc for a finish I dont know if it's cheap.. It came with the 6puk competition paddle clutch... But i would've thought it wont be as good as a geniune toyota one Quote Link to post Share on other sites
corofin12345 Posted January 27, 2014 Share Posted January 27, 2014 I dont know if it's cheap.. It came with the 6puk competition paddle clutch... But i would've thought it wont be as good as a geniune toyota one just ment anything other than a genuine release bearing mate... Quote Link to post Share on other sites
Socks Posted January 27, 2014 Share Posted January 27, 2014 I believe this person had the same issue with a non genuine release bearing... http://www.ukstarletowners.com/topic/67501-tuning-developments-bad-experience/ It seems redline & _shaun_ had the same issues as you with that particular clutch kit... I believe Toyota one will actually say TOYOTA on it somewhere... Ive been using my Genuine Toyota one now through 3 different clutch kits and several power outputs. Never had an issue! Quote Link to post Share on other sites
Starbuck Posted January 27, 2014 Share Posted January 27, 2014 Mine had issues too...still does.....within its warranty period and less than 4k Quote Link to post Share on other sites
Zeldoz Posted January 27, 2014 Author Share Posted January 27, 2014 Is this okay to drive? Quote Link to post Share on other sites
ryan lang Posted January 27, 2014 Share Posted January 27, 2014 input shaft/thrust bearing the clutch release bearing can be faulty from new, but my bet is against your old input shaft bearing having to deal with the bite that the paddle clutch now gives you if the sound goes with the clutch pressed in (when the release bearing is at maximum contact with the pressure plate) then i cant see it being that from what i can make from your description thats what you meant? Quote Link to post Share on other sites
mikey4410 Posted January 27, 2014 Share Posted January 27, 2014 dont drive it.didnt you see above with the damage etc ? Quote Link to post Share on other sites
Zeldoz Posted January 27, 2014 Author Share Posted January 27, 2014 I'll get a video I'm an hour Quote Link to post Share on other sites
Zeldoz Posted January 27, 2014 Author Share Posted January 27, 2014 Tried to get a video but it decided to play normal after work...Last night is the first I've noticed it.. Changing gears isn't any different to how it was before etc.. Possibly fluid related or an I being optimistic? Quote Link to post Share on other sites
Adam-Gt- Posted January 27, 2014 Share Posted January 27, 2014 Bearing !! Do you want to tackle the job in my lock up ? Quote Link to post Share on other sites
Zeldoz Posted January 27, 2014 Author Share Posted January 27, 2014 Bearing !! Do you want to tackle the job in my lock up ?Yeah why not. I'll supply lunch and energy drink!What do I need to buy? Quote Link to post Share on other sites
Adam-Gt- Posted January 27, 2014 Share Posted January 27, 2014 Check that other release bearing you have and get some gearbox oil were put fresh stuff in there Quote Link to post Share on other sites
Idrees Posted January 27, 2014 Share Posted January 27, 2014 Seen this sooo many times now...I wouldn't use ANY other release bearing bar one that says Toyota on it...There all shite! Even if you re-use and re-grease an old Toyota one its better then the new shite that comes with aftermarket clutchs these days...I have only ever heard of brand new release bearings being noisy with this particular brand of clutch kit. We have sold Comp Clutches, Blueprint, Exedy (OEM, Organic and Paddles) and we also supply new aftermarket release bearings. We've never had a single complaint! I have fitted 4 of the release bearings myself last Summer and none of them made a noise (can be proved as I still have a GT and a Glanza here, both using the release bearing we sell). Quote Link to post Share on other sites
Zeldoz Posted January 27, 2014 Author Share Posted January 27, 2014 Idrees how much are your bearings I'll need another! I Quote Link to post Share on other sites
