Hi All,
I have just decided to do a build thread after buying my car back in october 2013 so here it goes!
Spec List
Engine:
74.5mm ross forged
pauter rods
polished and knife edged crank
lightened pulley
all new bearings and seal
new cam belt
2mm Multi Layer Head Gasket
Fueling
470cc Injectors
255l Walbro Fuel Pump
TD High Flow Fuel Rail
Sard FPR
Cooling
AutoBahn Front Mount Intercooler
Alloy Civic Rad
Relocation Air Filter Kit(Come out just behind grill)
Turbo:
TD04 Hybrid Lateral Performance
Custom Downpipe
Full Exhaust System (Got a HKS Hi Power to be fitted)
Mild Steel Mani And Custom Exhaust
Custom Decat
Transmission:
spec 6puk paddle clutch
TD Light weight flywheel
Electronics:
Dastech Management Unit
Start/Cut off switch
Fan toggle switch
Fuel pump toggle switch
HKS EVC 6 Boost Controller
Chassis:
6 Point Carbing Roll Cage
Polycarbonate Sunroof
BMW E30 Wheels
Cusco Front Strut Brace
Poly Engine and gear box Mounts
White Line Front Anti Roll Bar
White Line Rear Anti Roll Bar
BC Coilovers
RSR Pan Hard Rod
Brakes
4 Pot Wilwoods
Braided Lines
Vented and grooved disc
Yellow pads
How I brought it:
1380028_10153356714065254_1001361072_n_z
1377234_10153356714130254_1986998544_n_z
1383953_10153356713965254_2091110115_n_z
1044402_10153356714385254_510469986_n_zp
1380465_10153356714270254_1606044265_n_z
Currently has print off running 247BHP 220lb Torque
Work Begins :)
Strip out all the rear
1375295_10153356714490254_22816192_n_zps
Clean up and rearrange the engine bay...
Current Condition
1380588_10153356714745254_1385390413_n_z
1385352_10153356715615254_1642709169_n_z
1378312_10153356715260254_738998287_n_zp
1374993_10153356715485254_133665364_n_zp
Started to do some cleaning up today will carry on updating
1395912_10153356715945254_2000687487_n_z
Found this while taking the intercooler apart for cleaning
537273_10153356716210254_935701329_n_zps
All sorted :p
1374993_10153356716905254_260529659_n_zp
Engine Bay All Sorted!
1392479_10153362143205254_204263754_n_zp
1381801_10153362143395254_1195697040_n_z
1379559_10153362143300254_325515819_n_zp
Started Painting The Back
37050_10153362143465254_1304425504_n_zps
Fitted RSR Pan Hard Rod
1392049_10153364997365254_152372789_n_zp
Had to remove sunroof to allow room for cage. before the roof can out
Polycarbonate Filler
Today finally got the time to work on the car/Losing my bite point so was time for the gearbox to come out (01/02/2014)
Found the Issue with the clutch
Think its time for a new flywheel aswell :)
After finding out the clutch was fucked decided to move onto the brakes as they have been sitting around for the last couple of months.
Has to take a bit off the heat shield to fit the disc
Brakes Finally On
Finished for the day :)
Edited by TD04HYBRID
  • Replies 92
  • Created
  • Last Reply
Top Posters In This Topic
UPDATE!
Here a few of the cage ( needs a tidy up)
So after finding out needed new clutch and flywheel and that i couldnt get that till Tuesday i decided to clean the gearbox and pain it up.
And spray a few other bits
Also Decided no need for a radio so took that out and getting ready to do a custom job there
So While i waited for my clutch & flywheel to come i started to custom make a gauge and toggle switch holder and start running the wires through.
Then done a template for the gauges and switches
Then Carbon Wrapped it
Toggle switches!
Then turn up 3 packages :) Spec 6 Puk Clutch/TD Lightened flywheel & HKS Hi Power Exhaust System
All bolted on
Will keep updating as best as i can
Starting to all come together now! Gearbox is all back on, driveshafts! Wilwood 4 pot brakes with grooved disc and yellow stuff pads in front, braided lines on rear all bled and tyres on! Noticed rad is leaking so new one on the way and thought I would check the thermostat is fully functioning noticed the seal had gone so need to order one! Toggle switches still need wiring up and then thinking about spraying inside and cage!
Will get up some pics once it's had a good clean!
  • 2 months later...
  • 2 weeks later...
Over the last couple of months i have been collecting parts ready to be assembled! really wanted to do the handling side before any more power but some things you cant refuse ;)
Full HKS Hi Power Exhaust - I fully heat wrapped the exhaust brought uprated mounts and all new gaskets
Full Blue Hose Kit
Sard Fuel Pressure With Braided Lines
Whiteline RARB
Whiteline FARB
TD Fuel Rail And Bradided Lines
Spare Rocker Cover to fit Braided lines to
Lil teaser of parts collection:
So after a load of effort to start work on the car after work as never have time the weekend the work had begun! i first started by getting my anti roll bar that i had sprayed fitted
I have been speaking Keith at Zisco that is making me a lil something for my TD04 Lateral Performance one off turbo :) so the stripping needed to be started
Exhaust half off need to cut it in half as previous owner decided to wield the joins :(
Comment welcome guys!
Nice project! Question on the switches, the fan is that to switch it on whenever you want?
Now the weather is getting hot, I'd like to add a manual override to my rad fan to keep temps cool
Ah sweet, would you mind taking a picture of where you have spliced into the wires please? And briefly just explain how you wired it?
