Zeldoz Posted February 13, 2014 Posted February 13, 2014 (edited) Been offered some celtica GT4 RED injectors for peanuts by a friend who has 12 in his garage lolI know the stock Glanza injectors are on there limits at 230bhp ish on an emanage blue.Would 540cc be too much? I don't know too much in terms of fuelling if having a too large CC can be negative..If not, how easy would it be to fit them?Would it be a wise move to get them on prior to my remap as I'm aiming at 1/1.1 bar on a TD04. Edited February 13, 2014 by Zeldoz Quote
Gainzy Posted February 13, 2014 Posted February 13, 2014 I wouldn't of thought you needed em my mate runs 220bhp on stock injectors get his brakes if you can haha Quote
akyakapotter Posted February 13, 2014 Posted February 13, 2014 I'm running stock injectors bud 233.4bhp if your not going over a bar just stick with the stock injectors Quote
corofin12345 Posted February 13, 2014 Posted February 13, 2014 lol, way too high mate plus they wont fit... pink top 3SGE injectors will tho.. glanza 4EFTE injectors = 295cccelica 3SGE pink top injectors = 315CCcelica/mr2 3SGE injectors green top 1994 onwards = 370cc Quote
Glanza-Ben Posted February 13, 2014 Posted February 13, 2014 Had 238.9bhp on stock injectors at 1bar Quote
_shaun_ Posted February 14, 2014 Posted February 14, 2014 Ran my td04 on my glanza at 1.3 bar with stock injectors and had no issues. Personally wouldn't bother changing them. Quote
Zeldoz Posted February 14, 2014 Author Posted February 14, 2014 I can buy them fot £20I'm wanting 1.1bar ideally..? Quote
mech5107 Posted February 14, 2014 Posted February 14, 2014 Ideally stock injectors run on logical duty cycle at around 200 HP. Higher power would need larger injectors. Usually 550cc from rx7 turbo.3sgte injectors are sidefeed so not going to fit. Quote
Zeldoz Posted February 14, 2014 Author Posted February 14, 2014 Ideally stock injectors run on logical duty cycle at around 200 HP. Higher power would need larger injectors. Usually 550cc from rx7 turbo.3sgte injectors are sidefeed so not going to fit.Really? I swear I've read a few people use the MR2 turbo injectors or the celica ones? Quote
Mike@TD.co.uk Posted February 14, 2014 Posted February 14, 2014 ST205 injectors wont fit a Starlet. As above they're side feed units. Thanks Mike JonesTuning Developments Ltd Quote
Phil Posted February 14, 2014 Posted February 14, 2014 Really? I swear I've read a few people use the MR2 turbo injectors or the celica ones? as mike says when it comes to injectors. 3sge 3sgte Phil Quote
Zeldoz Posted February 14, 2014 Author Posted February 14, 2014 ST205 injectors wont fit a Starlet. As above they're side feed units. Thanks Mike JonesTuning Developments LtdGutted. How annoying! Quote
