white-gt Posted March 2, 2014 Author Posted March 2, 2014 i went out tonight with the great help of jezza and changed the fuel filter,(BALL ACHE!) that got it started again which was strange! but then i noticed a wire loose on the throttle position sensor , could any one tell me if this could cause my issues? or what this wire is for? i know its getting supplied 5 volts so maybe that wire provides the power to the sensor? Quote
white-gt Posted March 2, 2014 Author Posted March 2, 2014 no mate, its idle again but still missing badly.. is it possible this wire is something to do with it?i tried to take the connector apart but their isnt a way to take the wires out and put them in again from what i can see.. Quote
white-gt Posted March 2, 2014 Author Posted March 2, 2014 yeh i think so or it gets better..but its pretty bad below that! Quote
akyakapotter Posted March 2, 2014 Posted March 2, 2014 Unplug the lambda sensor and take If for a drive 95% sure it will not missfire report back Quote
white-gt Posted March 2, 2014 Author Posted March 2, 2014 seriously? the tps wire wont effect it u dont think? Quote
white-gt Posted March 4, 2014 Author Posted March 4, 2014 well i tried a temp repair on this by wrapping the cables together and clamping them dow, STILL NOT BETTER! i tried disconnecting the lambda, NO BETTER! i changed the fpr, NO BETTER changed the leads, NO BETTER i checked the plugs and they where black though they have only covered like 2 miles if that! so i cleaned them up but still, NO BETTER! Whats left? so to clarify, if i try accelerate away in say 1st gear it splutters and if you dont dip the clutch quick enough it will cut out. Please people come on! Quote
white-gt Posted March 8, 2014 Author Posted March 8, 2014 well it turns out it looks like the wires on the top connector at the coil pack is slightly exposed.. it was shorting against the intake pipe, so i got it moved over and it runs much better but still has rather bad missing when you try accelerate harder.. would wrapping insulation tape around it help prevent the spark shooting out? im not sure what else i can do.. Quote
akyakapotter Posted March 8, 2014 Posted March 8, 2014 Yeah it will or a while until it makes it way through the tape Quote
Taggy Posted March 8, 2014 Posted March 8, 2014 does it misfire when you rev it in neutral or only when driving, the TPS can cause all kinds of erratic rev behaviour which sounds like its misfiring if its knackered, Quote
white-gt Posted March 9, 2014 Author Posted March 9, 2014 It only seems to be happening when under pressure.. so accelerating , it's fine in idle .What's my best method for sorting the issue ? What about using a glue gun and dripping it over the wires and that would act as an insulator ? No rbz I'm in ek.. Quote
Ollieh17 Posted March 10, 2014 Posted March 10, 2014 well it turns out it looks like the wires on the top connector at the coil pack is slightly exposed.. it was shorting against the intake pipe, so i got it moved over and it runs much better but still has rather bad missing when you try accelerate harder.. would wrapping insulation tape around it help prevent the spark shooting out? im not sure what else i can do.. i was right then i had the same, just wrapped it in electrical tape Quote
white-gt Posted March 11, 2014 Author Posted March 11, 2014 I've done that but it's still pretty bad... Quote
