Starlet-Joshy Posted February 24, 2014 Posted February 24, 2014 As above people, seen a Earls oil cooler on eBay looked good!Would this work with a N/a or would it cool the oil to much? Any help much appreciated, CheersJosh. Quote
richardc9052 Posted February 24, 2014 Posted February 24, 2014 Use a thermostat and it will be perfect Quote
rmsnoel Posted February 24, 2014 Posted February 24, 2014 Would an na get hot enough for it to need one? Quote
motion Posted February 24, 2014 Posted February 24, 2014 I only need one on track....once i had nearly 130°c now i got a 10cmx30cm one without thermostat but with a windshield when it is not needed Quote
mikey4410 Posted February 24, 2014 Posted February 24, 2014 as above just recently fitted oil cooler on turbo starlet mine as a prep for any track day i do as it stands atm it cools oil wayyyy to much even when half covered !!! mines fully covered and is just about acceptable now. you do not need an oil cooler on a starlet n/a Quote
Starlet-Joshy Posted February 24, 2014 Author Posted February 24, 2014 as above just recently fitted oil cooler on turbo starlet mine as a prep for any track day i do as it stands atm it cools oil wayyyy to much even when half covered !!! mines fully covered and is just about acceptable now. you do not need an oil cooler on a starlet n/aAh okay mate, just thought it looked good tbf and was cheap Atm, Cheers!! Quote
richardc9052 Posted February 24, 2014 Posted February 24, 2014 Well, if you have a thermostat you dont need to worry about covering it and if the case ever arose where the oil did get too hot, the thermostat would open and cool it down for you Quote
Xpect Posted February 28, 2014 Posted February 28, 2014 At what temperature should the thermostat open? What temp would be good for turbo and what for na Starlet? Quote
5T4R7ET N/A Posted February 28, 2014 Posted February 28, 2014 You need it to open around 85- 90 degrees Quote
littlegreenmonster Posted March 12, 2014 Posted March 12, 2014 Seew I've read that 70 degrees to 80 degrees is optimal for the n/a so most of the oil coolers would be good with a thermostat because they open at 80 Quote
