pointers to cut down the lag
Basically the simple answer here is get rid of your turbo and stick a td04 on there.
Td05 is a 3-350 bhp turbo which is in its element over 1.3/1.4bar which would blow a standard enngine in a short space of time so you would see the same bhp on a stock engine with a td04
  On 2/26/2014 at 2:41 PM, bajansuperman said:
well its not exactly a tdo5 of the evos its a t517z and i'm planin to run that kind of boost when i get a standalone ecu with 510 injectors
your not planning to run 1.3/1.4 pressure without forging !!?
  On 2/26/2014 at 2:51 PM, Socks said:
Shortest Boost Pipework you can get...
Mesh not a Filter...
Good Boost Controller & a Mapper that knows what there doing...
yea i'm currently running very rich and have to go down on injector size........ there is only soo much the afc can do :cray: till i get management that is
Edited by bajansuperman
