pointers to cut down the lag
Basically the simple answer here is get rid of your turbo and stick a td04 on there.
Td05 is a 3-350 bhp turbo which is in its element over 1.3/1.4bar which would blow a standard enngine in a short space of time so you would see the same bhp on a stock engine with a td04
Shortest Boost Pipework you can get...
Mesh not a Filter...
Good Boost Controller & a Mapper that knows what there doing...
yea i'm currently running very rich and have to go down on injector size........ there is only soo much the afc can do :cray: till i get management that is
Edited by bajansuperman
