chrisholly Posted March 11, 2014 Posted March 11, 2014 (edited) Hi Ok my car was a nice little runner for its age. I change the tubro to a gt28r running sweet as a nut new manford decat etc etcso I go change the waterpump and alternator. I got everythink back how it should be.go to turn it over and boom starts but it's hunting like mad so I turn it off. Turned it over again and starts but then it cuts out stuff that I have checked all seniors, spark, compression, earths, ignition timing, all coils, , fuel, wire's, the car bumped started. Ran ok on tick over but would not pick up the revs but it will not even bump start again!!? I have been trying for about a week now cant find everything about this on the web ;( all I want is to take my lovely car for a driveI really don't wanna break it, it would be such a shame if I have to ;( Edited March 11, 2014 by chrisholly Quote
Adam-Gt- Posted March 11, 2014 Posted March 11, 2014 It's hard to say with out looking , but change distributor cap to start with Quote
fremyjay Posted March 11, 2014 Posted March 11, 2014 You said you've checked ignition timing, what about the cambelt?? It may have slipped after you put it back on, if it was running before you done the waterpump i would say that could be the issue, if the timing was wrong when you first fired it up you could have had the valves hit the pistons, best bet would to check if you can turn it over by hand Quote
chrisholly Posted March 11, 2014 Author Posted March 11, 2014 Didn't remove the cam belt it started on a bump start and ran fine it just didn't pick up the revs the cam belt on mine is outside and not sat on the cam belt Quote
TimD Posted March 11, 2014 Posted March 11, 2014 The engine is non interference, so shouldn't have caused any internal damage afaik, but a compression test would confirm that. Quote
ryan lang Posted March 11, 2014 Posted March 11, 2014 why would it be the cambelt? hes hasnt touched that. water pump runs on the same belt as the alternator. chances are you've put something back on wrong like a vacuum pipe or left a vac pipe off somewhere Quote
ryan lang Posted March 11, 2014 Posted March 11, 2014 Didn't remove the cam belt it started on a bump start and ran fine it just didn't pick up the revs the cam belt on mine is outside and not sat on the cam belt cambelt is on the outside? :s Quote
5e colin Posted March 11, 2014 Posted March 11, 2014 swap back over to the old alt !!!!! u might have fitted a fucked alt as for waterpump the timing belt doesnt nead to come off !!! its only held on my 3 bolts to the block !!! Quote
chrisholly Posted March 11, 2014 Author Posted March 11, 2014 Do you think there is anyone around Bristol area I could pay to come have a look do you think It must be something really silly Quote
TimD Posted March 11, 2014 Posted March 11, 2014 Why not take some pictures of the engine bay and areas you've been and post them here. Quote
chrisholly Posted March 11, 2014 Author Posted March 11, 2014 Checked all vac pipes the car was working 100% till I played with alt and waterpump didn't touch anything else I will post pic for everything and a vid when I done my school run Quote
chrisholly Posted March 11, 2014 Author Posted March 11, 2014 Old alt was fucked to start with still ran and it's 5 bolts on the side I the block Quote
5e colin Posted March 11, 2014 Posted March 11, 2014 its 3 on the back of the block kid then the whole unit comes down Quote
chrisholly Posted March 11, 2014 Author Posted March 11, 2014 The alt has yea sorry fort yu was talking about the waterpump Kyle do you no anything about this fancy coming down and having a look I give petrol money if you can fix it I'll give you a days wage it even be something silly Quote
ryan lang Posted March 11, 2014 Posted March 11, 2014 cant see shit! pics are tiny and all need rotating Quote
chrisholly Posted March 11, 2014 Author Posted March 11, 2014 Sorry most of it are hard to get to Quote
ryan lang Posted March 11, 2014 Posted March 11, 2014 under the fuel pressure regulator theres a small pipe that goes into the number 1 runner on the inlet manifold, you havent left that off or knocked it off on accident. its in the area of the alternator so may have knocked it off Quote
chrisholly Posted March 11, 2014 Author Posted March 11, 2014 ok ill try it but it has no spark now for some how? it was sparking fine yesterday morning ;( Quote
seab Posted March 12, 2014 Posted March 12, 2014 (edited) Check for fault codes, I have had something similar on my Impreza and Glanza previously.Impreza turned out to be loose cam sensor so check yours is connected properly/ not broken (i.e a fault code).My Glanza did it with both air intake, and water temp sensors goosed (again check for fault codes on them or check continuity) Must add if the cam sensor is just loose you wont get a code. Maybe youve disturbed an already weak wire/connector on something. Edited March 12, 2014 by seab Quote
chrisholly Posted March 12, 2014 Author Posted March 12, 2014 I can't get code engine management light is not coming on :/ wtf going on it was all fine befor Quote
