cgmp Posted March 12, 2014 Posted March 12, 2014 Hey guys need some advice on some power upgrades on my N/A Starlet. Thinking about getting a new mani, straight through exhaust system, and intake upgrades? Where do I even start with this as I'm no where near a mechanic haha. I've heard corolla manifolds are quite common? Any advice would be great Quote
richardc9052 Posted March 12, 2014 Posted March 12, 2014 Firstly, a full service... Tubular intake manifold, gen 1 injectors and fpr, exhaust system. get it mapped on emanage.. You can change cams and springs but i think you might need to raise rpm limit to make use of the powerband if you went with the available 4efte cams. (not sure) Or you could bolt on a turbo and get it mapped on an emanage ;) Staying n/a you wont make more than 100-110 bhp unless you swap upto a 5efhe. Last but not least i think Chris Green makes ITB kits for 4e/5e's Quote
cgmp Posted March 12, 2014 Author Posted March 12, 2014 Firstly, a full service...Tubular intake manifold, gen 1 injectors and fpr, exhaust system. get it mapped on emanage..You can change cams and springs but i think you might need to raise rpm limit to make use of the powerband if you went with the available 4efte cams. (not sure)Or you could bolt on a turbo and get it mapped on an emanage ;)Staying n/a you wont make more than 100-110 bhp unless you swap upto a 5efhe.Last but not least i think Chris Green makes ITB kits for 4e/5e's Ok thanks man! I'll look into all that and try get it in for a full service next week! Not wanting to do any kind of crazy power upgrades as I'd rather just buy a glanza than strap a turbo on an N/A if you get me? haha! Where can I buy all these parts? Sorry I really don't have a clue! Quote
russ78 Posted March 12, 2014 Posted March 12, 2014 4efte cams are the same as 4efe cams just a side note Quote
mikey4410 Posted March 12, 2014 Posted March 12, 2014 been covered lots of times.just turbo it wether its in an n/a state or full turbo setup Quote
JLF88 Posted March 12, 2014 Posted March 12, 2014 I've currently change the intake manifold to a corolla 4efe tubular, next steps are 4afe throttle body, gen1 injectors, 4 branch exhaust manifold, 5e-fhe cams, emanage blue.Hope this helps, but as stated, it's been covered in various threads. Don't do a turbo conversion and follow the trend, try and do your own thing Quote
richardc9052 Posted March 12, 2014 Posted March 12, 2014 4efte cams are the same as 4efe cams just a side noteI meant cam upgrades for 4efte as I know they are the same but the upgrades arend designed for an n/a Quote
rmsnoel Posted March 15, 2014 Posted March 15, 2014 A regular oil change and drive it hard.Handling mods and good brake pads are a better place to start though Quote
