Jim* Posted March 15, 2014 Posted March 15, 2014 had some trouble with my car last night, struggling to select gears, at one point I could not select reverse, and also once gear was selected I could bring the clutch out 1mm and it would start to engage already. When pressing the clutch in also in neutral or in gear it would make a sound like there was something moving around in there.I'm pretty sure I need a new gear box but does this sound like the clutch has gone also?What could be the issue? I have spec paddle clutch from tuning developments 11 months old Quote
5T4R7ET N/A Posted March 15, 2014 Posted March 15, 2014 Check your clutch fluid reservoir, sounds like slave cylinder problem. Quote
theminiguru Posted March 15, 2014 Posted March 15, 2014 I also have gear selection problems and I have the same clutch? Mine is having issues going into gear? The car will hold the revs when the clutch is down? It doesn't do it all the time tho. I had my slave cylinder replaced and made no difference? My car will be going back to td soon for the guys to look at Quote
Jim* Posted March 16, 2014 Author Posted March 16, 2014 Mine does exactly that also, let me know if you find the problem!I also have gear selection problems and I have the same clutch? Mine is having issues going into gear? The car will hold the revs when the clutch is down? It doesn't do it all the time tho. I had my slave cylinder replaced and made no difference? My car will be going back to td soon for the guys to look at Quote
theminiguru Posted March 16, 2014 Posted March 16, 2014 Will do buddy. I few people have had issues with the same clutch. I'm convinced it's that :/ Quote
Glanza-Ben Posted March 18, 2014 Posted March 18, 2014 Mines the same right wanker to select 2nd and 1st when goin down the gears, I'm bleeding the clutch at week end to try solve this Quote
Jim* Posted March 18, 2014 Author Posted March 18, 2014 (edited) Mines the same right wanker to select 2nd and 1st when goin down the gears, I'm bleeding the clutch at week end to try solve this tried this to no avail Edited March 18, 2014 by Jim* Quote
Mikeyallgood85 Posted March 18, 2014 Posted March 18, 2014 Mine has just started doing it but it's not so difficult getting it into gear it's getting out of 1st gear it bites every so often! Same as mentioned above its not all the time once in a blue moon! 6 puk unsprung! I'm thinking it's the release bearing as I've read they are sh!t any of you still using the bearing that came with the kit just out of curiosity? Quote
Jim* Posted March 18, 2014 Author Posted March 18, 2014 Mine has just started doing it but it's not so difficult getting it into gear it's getting out of 1st gear it bites every so often! Same as mentioned above its not all the time once in a blue moon! 6 puk unsprung! I'm thinking it's the release bearing as I've read they are sh!t any of you still using the bearing that came with the kit just out of curiosity? mines the standard bearing Quote
Mikeyallgood85 Posted March 18, 2014 Posted March 18, 2014 Standard as in the one with the kit or you haven't changed from what you've had before you fitted the 6 puk? Quote
Jim* Posted March 18, 2014 Author Posted March 18, 2014 was fitted by tuning developments I can only assume he used the one from the kit Quote
Mikeyallgood85 Posted March 18, 2014 Posted March 18, 2014 The only reason I think thats the problem is when mine does it ive pumped the pedal to try release the engagement and it feels like its sticking like there is no spring back if that makes since! Its as if the bearing is sticking to the clutch plait and not allowing it to disengage! If you manage to find the source of the problem could you post it up. Quote
Jim* Posted March 18, 2014 Author Posted March 18, 2014 can do matey, it's off too tuning developments soon so hopefully getting fixed! Quote
Glanza-Ben Posted March 22, 2014 Posted March 22, 2014 (edited) I'm taking mine out asap as getting rid the clutch is shitEvery time I reverse it makes a noise like clutch is dragging and when I drop down it makes it aswell Edited March 22, 2014 by Glanza-Ben Quote
Jim* Posted March 22, 2014 Author Posted March 22, 2014 Seems like no end of people are Havjng problems with them! Quote
Glanza-Ben Posted March 22, 2014 Posted March 22, 2014 Seems like no end of people are Havjng problems with them!My car drove better with a stock clutch, this spec 6 just makes driving a nightmare Quote
fremyjay Posted March 23, 2014 Posted March 23, 2014 So whats a good clutch too use if there are so many problems with the 6puk, as i need to fit one next month and dont fancy having similar problems?? Quote
ryan lang Posted March 23, 2014 Posted March 23, 2014 if your having gear problems i feel bad for you son, ive got 99 problems but transmission isnt one Quote
Mikeyallgood85 Posted March 23, 2014 Posted March 23, 2014 My car drove better with a stock clutch, this spec 6 just makes driving a nightmare so true! I'll be heading to tuning developments soon so im going to try and get this sorted whilst im there or I'll be swapping it as well. Quote
