Ive got a project on the go. Putting a different engine into a Glanza. Im going to do the Abs delete and want to remove the power steering. What would be the best way to do it? Any way i can mod my steering rack that I've got or will i need to change it?
Google it theres alot of stuff on this out there pluq morgey talked about this a while back. It would hardly matter on a turbo car though..
Just to make you away the OP had been banned (again) as it was Sam mason trying to sneak back on after he was banned earlier this year.
Edited by rob_bower
Why not just remove the Power Steering fluid? Or the belt? So much easier lol
go try it, if you can deal with ut you'll look like a body builder in six months... lol
  • 1 month later...
I'm in the process of doing this my self
Removed all pipes to resevioir and to pump etc
Removed pump brackets and belts
Blanked off where the pipes fed up to the resevioir and the return from the pump with m16 bolts
But that's where in struggling
The other side where it goes hard pipes for the fluid to move to different sections of rack I've removed both pipes but I'm really struggling to find a bung to block off two of them but on two which stand up right on rack
I need to fit a couple of gease nipples to pump gease into the rack
This will help with non power steering
Has anyone done this if so please help me I've tried everything
3/8 whit
12mm
I've used imperial
Just can not find a gease nipple or bung to suit the threads :/
If anyone would help would be greatly appreciated
Chand
3/8 whit
12mm
I've used imperial
Chand
Chand, all I did was remove the whole lot, and cut down the 2 hard pipes that come out of the rack so they stick out about 2" or so and just loop it with a piece of braided hose. That's it..
I've been advised by tuner to pump gease in
How hard is it to turn etc?
Well fuck the tuner lol mines been fine for nearly 2 years now. The rack will still have fluid in it to keep it lubed up.
It's fine, as soon as you're moving it's pretty much like normal mate.
That's the best advise i get a lot lol fuck the tuner haha
You got any pic of excatly what you've done
You blank the holes which go to the res and the return from pump?
Then the other side where hard pipes come from what did you do blank them of link them aswell ?
Haven't blanked or blocked anything dude. Just strip the whole lot out til you get all the way to the sheering rack then you'll be left with 2 hard pipes, cut em down so they are eqal but stick out enough to get some braided hose and jibalee clips on.
I'll take a picture for you as soon as I can mate.
You haven't blanked anything
What about the pipes which aren't hard pipes mate the feed to reservoir and the return from the pump?
Yeah if you could do get some pics that would be great mate
Just go to your local hose spares or pirtex to make one up but take your old connectors with done mine braided 15 pounds
Loop it hydro pipe or braided Hydro
