scottieboi94 Posted April 2, 2014 Posted April 2, 2014 What rear lights does everyone think will look the best on a black glanza? Quote
Jamie5414 Posted April 2, 2014 Posted April 2, 2014 98 Spec Lights look good Reflet's are more for White/Silver/Red I think Quote
scottieboi94 Posted April 2, 2014 Author Posted April 2, 2014 I was looking at them but i think they look a bit bright tbh? Quote
scottieboi94 Posted April 2, 2014 Author Posted April 2, 2014 then again this looks good lol http://i232.photobucket.com/albums/ee247/ak13/glanzawashed006.jpg Quote
Jamie5414 Posted April 2, 2014 Posted April 2, 2014 They look smart, especially at night if you have the double side light mod Quote
daniel_g Posted April 2, 2014 Posted April 2, 2014 Carat lights, not to everyone's taste though, so rare, and funky as fuck !! Quote
scottieboi94 Posted April 2, 2014 Author Posted April 2, 2014 They look smart, especially at night if you have the double side light mod have you got any pictures of what that looks like mate? Quote
Jamie5414 Posted April 2, 2014 Posted April 2, 2014 (edited) So I thought i'd write it up, couldn't find it anywhere.... 98 Spec/Reflet Side light mod Before: After: Pins that I will refer to in this guide: You will need 2x Double Filament Bulb Holders (A breaker may have them in The Marketplace) ***Get a holder with wires sticking out as long as you can get, so you can solder onto them, otherwise it'll be a nightmare taking the holder to pieces to solder in wires. *** 2x Double Filament Bulb Wire (Two different colours: Green and White&Black (or just White)) Side Cutters Soldering Iron Solder Small Heat shrink (3mm) Heat Gun Cut the wires of the _bottom_ holders on each light and put them aside (Leave a bit of cable on the holder so you can always revert back and use the same holders). PASSENGER SIDE: Cut the Green wire on top holder, splice in a new Green wire and leave enough length to go to the bottom holder. Cut the White&Black wire on top holder, splice in a new White&Black wire and leave enough length to go to the bottom holder. Solder the new Green wire onto the "top pin" (Or the cable going to one, if you bought the holder with cables sticking out). Solder the new White&Black wire onto the "negative pin" (Or the cable going to it, if you bought the holder with cables sticking out). Solder the old (Reverse) Blue wire onto the "center pin" (Or the cable going to one, if you bought the holder with cables sticking out). DRIVERS SIDE: Cut the Green wire on top holder, splice in a new Green wire and leave enough length to go to the bottom holder. Cut the White&Black wire on top holder, splice in a new White&Black wire and leave enough length to go to the bottom holder. Solder the new Green wire onto the "top pin" (Or the cable going to one, if you bought the holder with cables sticking out). Solder the new White&Black wire onto the "negative pin" (Or the cable going to it, if you bought the holder with cables sticking out). Solder the old (Fog) Light Green wire onto the "center pin" (Or the cable going to it, if you bought the holder with cables sticking out). Insert double filament bulbs into each holder and insert into the light. Turn on JDMness! Jamie5414 Unsure if this is same on Glanza or not, but the guide is for N/A wiring Edited April 2, 2014 by Jamie5414 Quote
scottieboi94 Posted April 2, 2014 Author Posted April 2, 2014 I dont think it looks right with a space in between the two lights tbh Quote
Zeldoz Posted April 4, 2014 Posted April 4, 2014 I dont think it looks right with a space in between the two lights tbh That's JDM lights.. My glanza is like that as standard Quote
m_prior10 Posted April 7, 2014 Posted April 7, 2014 yea as zeldoz said they are JDM lights which come standard on glanzas Quote
Markgtni Posted April 10, 2014 Posted April 10, 2014 set of reflets and get the diy light tints of ebay but leave the red orange and clear stripes untinted? or even jus all tinted I think it would look class either way since your car is black Quote
cherrye10 Posted August 13, 2014 Posted August 13, 2014 Carat tailamps with clear lenses, 2 rings of red leds, outer one for light and inner for braking. Quote
DRiiFTiE Posted August 13, 2014 Posted August 13, 2014 I dont think it looks right with a space in between the two lights tbhMine mate http://i912.photobucket.com/albums/ac323/Nathan_Sherriff/Mobile%20Uploads/image_zps55df96f4.jpg Quote
lukeyy_EP91 Posted February 1, 2015 Posted February 1, 2015 Unsure if this is same on Glanza or not, but the guide is for N/A wiringWanting my lights like this on the sr!I'll need to replace my side with reverse light though won't i? Quote
