Critic Posted April 3, 2014 Posted April 3, 2014 So I'm just wondering what I can get done to fix this.I've already spoke with Rbz who has been awesome so far as always but I need more opinions/ help. Where the manifold bolts on, it has cracked around the head. Can it be welded? If it can be welded, does the head have to come off?If it can't be welded, do I need a new head? Any help would be greatly appreciated. Quote
AdamB Posted April 3, 2014 Posted April 3, 2014 Common problem, can be welded no problem but trying to find someone whos willing to take it on might be a little trickier. Quote
JDMfreak Posted April 3, 2014 Posted April 3, 2014 some guys use chemical metal around these to keep them going anyone with a tig welder should be able to tig it for you can be done while head is on but removing the turbo and manifold would make it handier Quote
Critic Posted April 3, 2014 Author Posted April 3, 2014 Common problem, can be welded no problem but trying to find someone whos willing to take it on might be a little trickier. That's the problem I'm having right now. Quote
iamlegend Posted April 3, 2014 Posted April 3, 2014 (edited) New head neededWelding is just a temp fix tbh... Peace of mind remove head and replaceSimples Edited April 3, 2014 by iamlegend Quote
Critic Posted April 3, 2014 Author Posted April 3, 2014 Where are you located lad? Newcastle Upon TyneNew head needed :/some guys use chemical metal around these to keep them going anyone with a tig welder should be able to tig it for you can be done while head is on but removing the turbo and manifold would make it handier Yeah I got told about chemical metal, not sure it would do the trick though. :/ Quote
richardc9052 Posted April 3, 2014 Posted April 3, 2014 If your ever around Preston area my cousin runs a fabrication business I'm sure you could get it welded there. I know it's far from you but just incase your ever I. The area Quote
Critic Posted April 4, 2014 Author Posted April 4, 2014 If your ever around Preston area my cousin runs a fabrication business I'm sure you could get it welded there. I know it's far from you but just incase your ever I. The area Ok. Quote
Vturbo Posted April 4, 2014 Posted April 4, 2014 I Had mine welded,it's been fine for the last 3 years Quote
Critic Posted April 4, 2014 Author Posted April 4, 2014 I Had mine welded,it's been fine for the last 3 years Did it happen in the same place? Quote
StarletSr? Posted April 4, 2014 Posted April 4, 2014 Your the second person this week whos posted about this! Quite common! A new head would be best but it can be welded. Quote
mikey4410 Posted April 4, 2014 Posted April 4, 2014 it common on cheap manifolds as they arent ever truely flat because they arent welded correctlythey cause excess pressure on certain studs and the above happens. Quote
rinseep82 Posted April 4, 2014 Posted April 4, 2014 You can use chemical metal mate but it won't last the trip to work I can assure you you can pick heads up pretty cheap mate personally ied just replace the head or weld it think there your options buddy Quote
Critic Posted April 4, 2014 Author Posted April 4, 2014 You can use chemical metal mate but it won't last the trip to work I can assure you you can pick heads up pretty cheap mate personally ied just replace the head or weld it think there your options buddy Yeah I've thought about buying a new head. It's just finding one, then its finding someone to do the swap over. I was even playing with the idea of taking it off the road for couple months to save up and just buy a new engine. :/ Quote
iamlegend Posted April 4, 2014 Posted April 4, 2014 Yeah I've thought about buying a new head. It's just finding one, then its finding someone to do the swap over. I was even playing with the idea of taking it off the road for couple months to save up and just buy a new engine. :/ new engine over a cracked head? Quote
Critic Posted April 4, 2014 Author Posted April 4, 2014 new engine over a cracked head? I should have said, saving up and buying a forged engine. :/ But yes I know it stupid. I just can't find anyone who will touch this... Quote
richardc9052 Posted April 4, 2014 Posted April 4, 2014 If your struggling to find in the uk I can probably get you one in Ireland cheap. Would probably only have valves, springs and caps for the cams. Le me know and I'll get a price for one. Quote
Critic Posted April 4, 2014 Author Posted April 4, 2014 If your struggling to find in the uk I can probably get you one in Ireland cheap. Would probably only have valves, springs and caps for the cams.Le me know and I'll get a price for one. If I get stuck I'll drop you a message. Quote
Vturbo Posted April 5, 2014 Posted April 5, 2014 (edited) Did it happen in the same place?Yeah mate exactly the same place. Pretty sure the head has to be removed as a new hole has to be drilled and threaded after it's been filled with metal. Edited April 5, 2014 by Vturbo Quote
