Well its now a Van! got all the floor sorted out over the weekend, I have done this one in 1/2" ply so its a good bit stronger than the one in the SR!
F5265532-D4C3-405F-A5BD-1D70390FB2CF_zps
37210DB3-4724-44B9-8041-73AD47B8C0E2_zps
73F1455F-A7C5-458F-9DFF-BA255FF82845_zps
Covered it in bus flooring because its nice and tough, non slip and easy to clean!
98F91C46-D6CD-42CC-A657-7BC32F210D09_zps
02B8D59F-1D7E-45F9-841A-966405314428_zps
I also put a back board in too to stop things sliding into the front!!
F66BE23C-82B4-47E4-8E68-66A21C204F56_zps
I added braces from the seat back mounting points to the board too also so they can be used to strap things to! Then installed the alarm and dogwoofer combo! in the back!
FEB08ABF-8C01-4620-B726-86F3AF146B85_zps
  • 3 weeks later...
  • 5 months later...
Well after running this all winter, Now the SR is all up and running again I thought Id give this some much needed TLC seen as the brakes where sticking on the fronts and I knew the rears where getting very low. So I got it on the ramp and pulled all the wheels off!
DD940784-8043-45BD-A523-D2890D46147B_zps
DD2CC54B-86EE-42C6-8C74-0166547ABC55_zps
N/S
0FDF68A4-E2C2-4B0D-93CB-1F8F65C1FDB3_zps
O/S
8EE4DCFA-B24F-4AAB-88B5-FA49C800AD4F_zps
28170EC1-60BB-41E1-9011-AA0DFF29F8D4_zps
So I replaced the rears! then onto the fronts
The Callipers on the front where seized up when I got the car I freed them off but it did't last long and also the discs that where on the car where too small for the callipers for some reason! But I had some very good 98 spec glanza callipers and carriers so I ordered some new glanza discs and pads. The first set of discs I was sent where bigger than the ones that came off but still too small for the glanza callipers!
A538EF2F-3CC8-4BAD-97F2-5D9CCF55A628_zps
D7D80A0D-479C-4A83-8140-DEC0A2319B38_zps
The 2nd set I got fit properly!!
4301F408-0E6B-48A8-934E-27B616EE86F7_zps
696F2A5A-3541-4566-A91D-9FEB1DAA9BC4_zps
I also did the timing belt kit and the aux belts too while I was at it! Im going to keep this on the road all year round as its such a handy car to have!
