morgey Posted April 18, 2014 Posted April 18, 2014 is the only option to buy bride rails or is there other rails out there that can be used? its a fixed bucket with the mountings on the bottom. could you modify stock seat rails to suit if so has anyone got any pictures of how they've done it please. much love Morgey Quote
ryan lang Posted April 18, 2014 Posted April 18, 2014 i modified stock rails with a bar bought from b&q but i unfortunately dont have an pictures :/ all i did the was cut the old mounting points (that the seat bolts to the rails) off the standard rail and then weld 2 bars across the rails and drill holes for the seat to bolt too Quote
morgey Posted April 18, 2014 Author Posted April 18, 2014 Any chance of a picture aidan? Pretty sure I know what you mean but I've got to explain it to a girl (no offence to any on here lol) Quote
morgey Posted April 19, 2014 Author Posted April 19, 2014 Ahh shame. What's the rough cost of a bride rail then guys? Quote
Amjad Posted April 20, 2014 Posted April 20, 2014 I've seen rails go for anywhere between £50-100 eachDo fixed rails pass MOT? Quote
Socks Posted April 20, 2014 Posted April 20, 2014 I have a base mount for Bride Rail for EP91 Morg if you need one! Quote
Socks Posted April 20, 2014 Posted April 20, 2014 What do you mean by a base mount? Recliner... Mounted from the bottom? Not Side Mounted... You need L brackets to mount a side mounted seat I presume! Quote
Beastmode panda Posted April 20, 2014 Posted April 20, 2014 I cut off the old feet from the oem seat, drilled a hole in said feet then put a bolt through the subframe of the seat to the feet then bolted it to the car. Simple. Quote
morgey Posted April 20, 2014 Author Posted April 20, 2014 (edited) Recliner... Mounted from the bottom?Not Side Mounted... You need L brackets to mount a side mounted seat I presume!Oooo I get ya lol. I've only just woke up. I'll have a word with her and see what she wants to do.Pm on route socks Edited April 20, 2014 by morgey Quote
ryan lang Posted April 21, 2014 Posted April 21, 2014 hopefully these are of some help to you aha. managed to track down and get some pics of mine not the best but hopefully its a help lol the sliding part of the rail is 2 parts, so ive simply just welded 2 bars from either side, and drilled holes in it ryan Quote
morgey Posted April 22, 2014 Author Posted April 22, 2014 Nice one. Cheers Ryan ill fire these pics over so she can see what you've done. Quote
ryan lang Posted April 22, 2014 Posted April 22, 2014 they are not the best pics in the world to help explain, but they still slide back and fore etc so they are pretty decent admittedly a bit stiff to slide if fitted to an ep91 because when we welded them we used an ep82 shell (my old GT) to bolt the rails to, to tac weld the bars in place but a good safe set of sliding rails none the less you'll see what i mean when you take the standard one apart anyway dude Quote
