Jamie5414 Posted April 24, 2014 Posted April 24, 2014 Hi, What would I need along with the turbo kit to make a Ct9 work on a 4efe engine? Running 0.5bar or something like that for a bit of extra power. HKS ActuatorCt9 TurboCt9 ManifoldCt9 DecatInter cooler Is what I would have to start with, what else would I need in my shopping basket so I can see what it'll cost? 4efte Injectors? Some sort of management upgrade?Fuel Pump upgrade? Any sensors etc? What would I need along with my 5 items above, and what could it be ran at (in bar) without getting mapped? Or would it just run like shit? Quote
Ollieh17 Posted April 24, 2014 Posted April 24, 2014 Need to sort an oil feed and return to the turbo Quote
Jamie5414 Posted April 24, 2014 Author Posted April 24, 2014 Would a Glanza sump bolt onto 4efe like for like? or an alternative oil return location? Quote
5e colin Posted April 24, 2014 Posted April 24, 2014 4efte injectors4efte oem oil relocater4efte sump / pick up 4efte fly clutch 4efte thermostat housing emanage blue on existing wiring or convert to 4efte wiring map sensor Quote
Jay85 Posted April 24, 2014 Posted April 24, 2014 For what it'll cost ya you could pick up a gt, would prob be cheaper tbh Quote
daniel_g Posted April 24, 2014 Posted April 24, 2014 Right there is a few ways you can do this and not everyone will agree on this but i think the best way is to get a turbo ECU and get everything else that runs it and bolt the lot a FE engine.Parts i used when converting the 85, all from a GT, so if its a 91 then just get all Glanza parts.ECUEngine loomDash loomInlet manifold, throttle body & sensorsMAP sensorInjectorsFull turbo ignition system,Coil / ignitorIgnition leadsSpark plugsDizzyThermostat housingOil filter housingSump modded for a return or a turbo sumpIntercooler kitVF12 turbo kit, mani, downpipe, turbo, oil & water lines, wastegate & screamerTurbo flywheel3 puk paddle clutchThink thats it, i used a turbo PAS setup aswell.People may have more to add or say you dont need it all Its really easy Jamie give it a shot bud. Quote
Jamie5414 Posted April 24, 2014 Author Posted April 24, 2014 Interesting, It does seem that way Jay, may be a good thing I wouldn't mind a Mk1! Thanks Colin and Daniel, i'm going to price up how much the main bits will cost and see if it's worth it for me I wouldn't mind a bit of extra power Quote
daniel_g Posted April 24, 2014 Posted April 24, 2014 It doesnt cost a lot at all bud, just find someone breaking a V or GT near you and get all the bits from them.Aslong as you use looms from a V thats the same year as your 91 then it'll be really straight forward. Quote
