Are glanza and gt front oem braces the same and will a turbo strut brace fit a N/A?? Thanks!
Right, gave a man a glanza strut brace and he tells me it wont fit his glanza! his only has 3 bolts on the strut tower, I thought most glanza's had 4? would it make a difference?
You will need to bend the fuel filter out the way iirc
yep, cheers, done that but the problem i'm hveing here is the holes wont line up with the bolts!
Ah don't talk to me haha, but when he wont hold up his end of the swap till this is sorted i'm in trouble!
