Dale SR Posted May 17, 2014 Posted May 17, 2014 (edited) Hi thanks in advance for helping dose anybody know how to remove the center console stereo surround on the ep82 cant for the life of me work out how to get it off and don't want to start pulling bits off and breaking them. i would appreciate any help. ThanksDale Edited May 17, 2014 by Dale SR Quote
JamesD89 Posted May 17, 2014 Posted May 17, 2014 gently pull the main surround out and there are screws behind it Quote
Dale SR Posted May 17, 2014 Author Posted May 17, 2014 gently pull the main surround out and there are screws behind it perfect thanks mate. Quote
Dale SR Posted May 17, 2014 Author Posted May 17, 2014 I've managed to unclip the bottom of the surround, dose the top just unclip as-well, it feels fairly suck in? Quote
JamesD89 Posted May 17, 2014 Posted May 17, 2014 It will only pull out so far and you should be able to see one screw each side undo them and it will pull straight out Quote
Dale SR Posted May 17, 2014 Author Posted May 17, 2014 It will only pull out so far and you should be able to see one screw each side undo them and it will pull straight so the surround wont actually come off, just undo the two screws for the stereo. Quote
JamesD89 Posted May 17, 2014 Posted May 17, 2014 No the surround needs to come off first iirc the screws are behind it once you have pulled half way out you will see them Sorry about my wording had a couple of bottles of grolsch James Quote
Dale SR Posted May 17, 2014 Author Posted May 17, 2014 No the surround needs to come off first iirc the screws are behind it once you have pulled half way out you will see them Sorry about my wording had a couple of bottles of grolsch James cheers for your help ill have another go, nah your wordings fine Quote
Dale SR Posted May 17, 2014 Author Posted May 17, 2014 really struggling with this! I've managed to unclip the bottom clips of the surround, but cant see any screws apart from the ones securing the stereo, do i need to pull more of the surround away before finding the screws your on about? Thanks Quote
JamesD89 Posted May 17, 2014 Posted May 17, 2014 Yeah pull the whole console out mate makes it more accessable the outer surround that the heater vents sit in needs to be pulled out and unscrewed, piss easy from there man i will send you pics tomorrow if your still stuck. James Quote
Dale SR Posted May 17, 2014 Author Posted May 17, 2014 Yeah pull the whole console out mate makes it more accessable the outer surround that the heater vents sit in needs to be pulled out and unscrewed, piss easy from there man i will send you pics tomorrow if your still stuck. James sound was worried about pulling the top of it and braking it, ill give you a shout if i don't manage, thanks again for your help Quote
Dale SR Posted May 17, 2014 Author Posted May 17, 2014 nah a cant get it off, all i can do is unclip it a bit at the bottom the middle and top are really stuck in place this is piss easy to take off on the ep91s so frustrated Quote
MARC MOSS Posted May 17, 2014 Posted May 17, 2014 The aircon and fan control buttons have to come out first then the screws are behind it mate Quote
patman Posted May 17, 2014 Posted May 17, 2014 What Marc said very thin flat head screwdriver and ping the heater control strip off the screws are behind that 👍 Quote
JamesD89 Posted May 18, 2014 Posted May 18, 2014 Yeah as above mate sorry belgium lager make me no speak good. A pic for reference. Quote
Dale SR Posted May 18, 2014 Author Posted May 18, 2014 The aircon and fan control buttons have to come out first then the screws are behind it mate What Marc said very thin flat head screwdriver and ping the heater control strip off the screws are behind that Yeah as above mate sorry belgium lager make me no speak good. A pic for reference.awww i see now, thanks for all your help guys. Quote
