can any one tell me what is the cause of this i changed plugs and wires so those r fine, my fpr is set at 20 stock injectors standard ecu wideband show car idle at 11s to 12s when all four cylinders are working and 17s and up when spark in cylinder one is out
have you tested the other cylinders to see if spark is missing on those as well?
if its just one cylinder, then its most likely the wire, plug or cap ------and you said you changed those
yea all four are working i pulled out each wire and did the screw driver test got shocked and all lol soo the wires r working changed plug to new then tried the old something so dont think its those also seeing liquid come out that cylinder by manifold
Edited by bajansuperman
