bajansuperman Posted May 18, 2014 Posted May 18, 2014 can any one tell me what is the cause of this i changed plugs and wires so those r fine, my fpr is set at 20 stock injectors standard ecu wideband show car idle at 11s to 12s when all four cylinders are working and 17s and up when spark in cylinder one is out Quote
mikey4410 Posted May 18, 2014 Posted May 18, 2014 Well it has to be either dizzy cap , plug or lead dude.theres no way a coil pack can be at fault. Quote
gorganl2000 Posted May 21, 2014 Posted May 21, 2014 have you tested the other cylinders to see if spark is missing on those as well? if its just one cylinder, then its most likely the wire, plug or cap ------and you said you changed those Quote
bajansuperman Posted May 21, 2014 Author Posted May 21, 2014 (edited) have you tested the other cylinders to see if spark is missing on those as well? if its just one cylinder, then its most likely the wire, plug or cap ------and you said you changed those yea all four are working i pulled out each wire and did the screw driver test got shocked and all lol soo the wires r working changed plug to new then tried the old something so dont think its those also seeing liquid come out that cylinder by manifold Edited May 21, 2014 by bajansuperman Quote
Bristol glanza Posted May 21, 2014 Posted May 21, 2014 if it was me. take all 4 plus out, earth them on something on the car, turn the car over, check for spark on all 4. it maybe dizzy cap or leads.spark plug gap i am guessing? Quote
bajansuperman Posted May 21, 2014 Author Posted May 21, 2014 i did it by putting a long screw driver in the wire and laying it on the cam cover saw spark Quote
bajansuperman Posted May 21, 2014 Author Posted May 21, 2014 sounds like a boat and when i pull number one wire no change in idle Quote
