Jamie5414 Posted May 21, 2014 Posted May 21, 2014 Hi, Upgrading the clutch on my 4EFE for when i covert it to a turbo, It's an Exedy Organic clutch kit. Should I clean up and re-use my old Toyota release bearing, or put in the new one that's supplied? I've heard they can make noises etc only 100 miles after install? Thanks,Jamie Quote
turbo Grant Posted May 21, 2014 Posted May 21, 2014 I've alway use the new bearings with clutch kits. Never had a problem Quote
GlanzaJ Posted May 21, 2014 Posted May 21, 2014 I used the same clutch and mine makes a noise already after a week ! Quote
Gainzy Posted May 22, 2014 Posted May 22, 2014 The way I see it is it takes a good couple hours work to change the clutch might aswell put a new release bearing in, OEM parts are always better to use, buy a new oem one imo Quote
fiddlersport Posted May 22, 2014 Posted May 22, 2014 oem all the way because them aftermarket cheapish brands only last a few weeks and then the noise comes back Quote
