hi lad your better of just ordering them from your nearest engine engineering or motor factor, the last set I bought was FAI and only cost £28.80. from powermax engineering.
kevin
Edited by glanzatd04l220
Thanks for the replies guys, my local Motor factors don't List them and Toyota want 100quid and about a week maybe more to get them :/ I'll check Out that link and go from there
Someone must have a set laying about unused so I don't have to pay top Dollar?
Poxy car has cost me too much as is :(
I have some original toyota ones mate all 16 of them had a spare set but how desperate do you need them? Will do you £40 posted as they will be going 1st class recorded pm me mate if interested
Pat
If I'm honest, I thought, I'll replace the valve stem seals while I'm there, they'll only be 15 quid, rang the Motor factors at work And None of them Have Them, so I posted on Here thinking I'll find some cheapish ones, but it Seems they are quite expensive everywhere you look lol
It's Knowing what ones will definitely fit though grant, anyone know if 4e-fe seals are the same? As they're Like 15quid lol
FAI vsk325 (pa617) that's the part number for the steam seals I used lad there for a Mitsubishi lancer but are the same size and there doing the job nicely, where only £28.80 but id say you'll get them cheaper on ebay.
kevin
yes mate the FAI vsk325 is the part number for the Mitsubishi lancer and the ( pa617 ) is the Toyota number but there both the same oil stem seal and work a treat.
kevin
