When I first fitted the clutch it was really bad to drive but after adjusting the pedal it was fine, so I think it was working ok, disengaging fully.
However I actually just remembered that I'm not sure what bearing it is I'm running! (I'm getting old!) :sorry:
I did fit the one I got with the clutch but it was second hand and I didn't really pay attention to it at the time, when I had it out last time to change the friction plate I did check it though:
The one on the right is currently fitted - not sure if it is an ORC one though!?
I'm also starting to wonder if I did put the friction plate on the wrong way round, but I thought it was the same either side?
Edited by WallaceGlanza
No plates not the same both sides mate, so is possable its on the wrong way and the one on the right is defo an orc bearing. Is also the same as the blitz clutch and exeedy hyper power twin plate clutches.
Hopefully mate, ive checked mine and seeing as its just an organic theres only one way it go on. Really annoying me now as I just want it bloody working again!! My just send it to a garage and pay the price
Whats up with your clutch Rich?
Gonna chuck a bolt in my slave cylinder to rule out that possibility before I change the box
Edit: Didnt work so ill be swapping the box out, hopefully the box works
Edited by Cushion
