WallaceGlanza Posted May 26, 2014 Author Posted May 26, 2014 (edited) When I first fitted the clutch it was really bad to drive but after adjusting the pedal it was fine, so I think it was working ok, disengaging fully. However I actually just remembered that I'm not sure what bearing it is I'm running! (I'm getting old!) I did fit the one I got with the clutch but it was second hand and I didn't really pay attention to it at the time, when I had it out last time to change the friction plate I did check it though: The one on the right is currently fitted - not sure if it is an ORC one though!? I'm also starting to wonder if I did put the friction plate on the wrong way round, but I thought it was the same either side? Edited May 26, 2014 by WallaceGlanza Quote
shorty Posted May 26, 2014 Posted May 26, 2014 No plates not the same both sides mate, so is possable its on the wrong way and the one on the right is defo an orc bearing. Is also the same as the blitz clutch and exeedy hyper power twin plate clutches. Quote
WallaceGlanza Posted May 27, 2014 Author Posted May 27, 2014 Well hopefully it's just me being a retard that's caused this problem then! Will get the box off and check which way round the plate is. Quote
Cushion Posted May 27, 2014 Posted May 27, 2014 Hopefully mate, ive checked mine and seeing as its just an organic theres only one way it go on. Really annoying me now as I just want it bloody working again!! My just send it to a garage and pay the price Quote
WallaceGlanza Posted May 28, 2014 Author Posted May 28, 2014 (edited) Nope, not had time to get the box off yet, will make a start tomorrow night and hopefully have it off at the weekend. Edited May 28, 2014 by WallaceGlanza Quote
WallaceGlanza Posted June 4, 2014 Author Posted June 4, 2014 Might sound daft but i've seen it done, friction plate on the wrong way ? 10 points to Daniel! I R Rtard. Quote
richardc9052 Posted June 4, 2014 Posted June 4, 2014 (edited) Damn.. thought your problem would have been similar to mine GLad you got yours sorted though mate Edited June 4, 2014 by richardc9052 Quote
Cushion Posted June 5, 2014 Posted June 5, 2014 (edited) Whats up with your clutch Rich? Gonna chuck a bolt in my slave cylinder to rule out that possibility before I change the boxEdit: Didnt work so ill be swapping the box out, hopefully the box works Edited June 5, 2014 by Cushion Quote
