Wat boost to run on ct9 hybrid
Hi I have a ct9 hybrid
5zigen decat
Toyosorts manifold
Hks actuator
Hks fcd magnecor ht leads
Standard ecu
I have a sytec fpr that I will be fitting aswell
Wat boost do people recommend to run it's currently running 1 bar but I think that May be to high?
People run all sorts some people say there's no point to run more than one bar as it poofs the turbo out. if its running one bar at the minute id leave it unless you want piece of mind go to 0.8.
Hopefully someone els can give you a better answer to reasons etc
Edited by Dean_mc88
The answer really is no- not safely.
fuel pumps,injectors,brand of rrfpr,all have an effect on what different precise fuel preasure you need.
others may say different but I would never guess or hope somebody has an " answer"
get a afr gauge or go to a dyno and have them set up ure afrs.
hope this helps
I'd run it about 5.3 bar just to be on the safe side and set fpr to 17.7 bar and you should be fueling correctly , I ran this on my non turbo jdm uk n/a for 10 years and done 138mph in reverse
Fucking poser and it was diesel
