just recently my wideband has been reading rich 11.3 when shes warm.
reads 14.7 from cold start but goes rich after few minutes driving, car seems to be running as normal just weird readings :/
disconnected the lamdba and made no difference to the readings, does this mean i need a new one?
also checked for vacuum leaks an cant see anything
anyhelp would be great lads!
As I found recently my wideband sensor failed
readings were mental
inwent on a wild goose chase for weeks as I never thought it could have been faulty.
Not saying its defo that but please remeber it could be a possibility.
At cold start should be around 11 to 12.
14.8 at idle and cruise when warm
11-11.5 at wot
mines always been 14.7 @ cold start and idle and cruise
reads 11 when wot
then just like 12 -13 when cruising
my sensor did mess around a few months back after washing my engine bay but it came back an worked normal again.
wideband sensors are a rip off too! lol
Yes you can. the plx has 2 outputs, one wideband and one narrowband unlike the others where you have to switch the two. I am however unfamiliar with the wiring of the plx so if you can find out which wire does what, snip the lambda wire near your ecu and connect it to the wire from the plx.
Update!
Ran her on the widebands narrowband
Got sum weird readings
11 on cold and warm idle
11 on cruise
On wot she went 14.7 then 10
An she seemed to be running rough an ya could smell the fuel :/
Switched back to normal wideband an running better an same readings as before
Think my wideband sensor is knackered
Wat yas think???
