forged engine spares or repair
Item For Sale:for sale is my 4e forged engine sadly the bottom ends started knocking two days ago it's fine on idle just when you rev over 3k it start knocking a little the car was stopped straight away after this and the cranks was checked it has slight scoring so will need a reground and new shells this engine was built a year and a half ago a bought it from someone on this a didn't get recipes for the build but a got loads of pictures of when the engine was built also got pictures with sump off that was only taken yesterday
Item Condition & Description:
Genuine toyota oil pump
water pump
new timing belt kit
new engine seal kit i.e (crank seal, rear main, cam seal)& gaskets crank & flywheel lightened & balanced when block was bored
wiseco 74.5mm forged pistons
scat forged rods (block notched to fit them)
ACL racing big ends, mains & thrust bearings
athenna 1.2mm metal headgasket
crusie valve springs
valves lapped in
uprated valve stem seals
NGK iridium heat range 8 spark plugs
arp headbolts
Price:900
Pictures: 20140616_002131_zps7397b49f.jpg
10320470_10154146341110371_2335238559372
10363130_10154146341165371_8316597925931
10169340_10154146341090371_9657862332068
Payment & Shipping Details:
The picture you've stuck up is that not a set of headstuds not bolts who built the engine?
The pictures a have put up was the ones a got from the boy that a got the engine from he said someone from glasgow built it his nane was dave borrows built it
I paid £200 for fucked forged lump with perfect wiseco pistons and one damaged pauter rod.
you got a good deal there then ae mines not going for any less that 800 if it doesn't sell Al fix over time skint at the moment or a would fix it myself
never mind this is actually boost junkies engine. he built it and moved to canada so the car was garaged for like 3 years.someone must have bought the car and broke it
Edited by _shaun_
the boy a bought it from was alex bennet he said the car was garaged like but didn't say for 3 year he said the car belonged to his cousin that moved to Canada and he was breaking the car for him
U got shafted. Forged engines should last ages
Not allways the case!! Depends who has built it and if it has been built properly ask any tuner most of them will say they have to repair more forged engines than standard ones because of shoddy workmanship just because it's forged dosent mean it's been built to the standard it should
If you look in the sales section he's got the add for him trying to sell the whole car. He's also got a build thread but it was waaay back in 2011 I met him and he was just moving away
just spoke to boost junkie basically he just told me he sold his unfinished ep82 to alex bennet he advised alex to get the oil pump changed as it wasn't getting oil pressure so the wee fanny has sold me a fucked engine why can people do that to someone his day will come tho engines not fir sale anymore please lock
Not for sale anymore please lock
