Sign in to follow this
Tyler
5e conversion
I've got a na starlet ep91 and a 97 paseo. I want to put the 5efe in my starlet but I don't know how complicated it would be?
And I've been thinking about turboing the 5efe but is it worth it?
Share this post
keep al electro from original car to run it even injectors to make fitting easy
then you need a wideband and a adjustable feul pressure regulator to increase feul pressure a tat to have her running good afr at WOT ( downside shit idle )
dont be revving the shit out of her till its checked
or get a sub and get it mapped
edit just noticed this thread is 6 months old !!! dhuuu
Edited by 5e colin
Share this post
Colin, im thinking of getting a 5efte done, the engine from a toyota sera any good? are they they 5efhe? and is it just bolt the 4efte head onto the bottom end of the 5e and use the 4efte sump and the 5e flywheel?
Share this post
yes mate they have the fat rods in them there very strong , fit 4efte pistons to them rods and fit 4efte sump pick up on it , with the thermostat housing to
get your 4efte fly redrilled by and engine builder / engineers then get the fly rebalanced !!! ( its a must ) the 200mm clutches wont hold the power long they even struggel on a 4e ct9
Share this post
yeh ive got a td04 in mine lol, but is it worth doing all this? what are the power gains like?
Share this post
mainly for spool on larger turbo kits, dont like being revved either...........blew mine up.... :thumbsup:
Share this post
5E ct12 combo somebody go for it lol you won't be bothered about big power figures as the response will be crazy done right!
Share this post
