fremyjay Posted July 23, 2014 Share Posted July 23, 2014 (edited) glanza thermostat housing with all sensorswater pipe from thermostat housing to water pump pipe behind blockrrfprboth fuel line breather pipesTop cam cover with boltsPanel under the windscreen Edited July 29, 2014 by fremyjay Link to post Share on other sites
_shaun_ Posted July 23, 2014 Share Posted July 23, 2014 The sensors differ between the 96 and 98 spec which you after? Link to post Share on other sites
fremyjay Posted July 23, 2014 Author Share Posted July 23, 2014 Mine been chopped off so need the plug and a bit of wire too, so I would say it wouldn't matter too much Link to post Share on other sites
fremyjay Posted July 25, 2014 Author Share Posted July 25, 2014 ^^^ Link to post Share on other sites
fremyjay Posted July 26, 2014 Author Share Posted July 26, 2014 Still looking Link to post Share on other sites
fordie_glanzaV Posted July 26, 2014 Share Posted July 26, 2014 I got a lambda sensor kicking about u can have to try :-D Link to post Share on other sites
Socks Posted July 26, 2014 Share Posted July 26, 2014 http://www.ukstarletowners.com/topic/83856-3x-adjustable-fuel-pressure-regulators/#entry1025810Drop me a pm if you like. Link to post Share on other sites
Flintygt Posted July 26, 2014 Share Posted July 26, 2014 I have a fuel pump? £40 posted works perfectly? Link to post Share on other sites
fremyjay Posted July 26, 2014 Author Share Posted July 26, 2014 I got a lambda sensor kicking about u can have to try :-DNeed plug too dude, as someone cut one off my loom http://www.ukstarletowners.com/topic/83856-3x-adjustable-fuel-pressure-regulators/#entry1025810Drop me a pm if you like.Might have found one but will pm you if not bud I have a fuel pump? £40 posted works perfectly?Is it a walbro dude and is it in the unit already?? Link to post Share on other sites
fordie_glanzaV Posted July 26, 2014 Share Posted July 26, 2014 Ahhh right... well lambda there if you need it.... Sorry to spam but u dont have std rad kicking about do you? Link to post Share on other sites
Flintygt Posted July 26, 2014 Share Posted July 26, 2014 Is it a walbro dude and is it in the unit already?? Link to post Share on other sites
TD04HYBRID Posted July 26, 2014 Share Posted July 26, 2014 I got the manifold gasket and lamda sensor with plug pm me s offer Link to post Share on other sites
fremyjay Posted July 26, 2014 Author Share Posted July 26, 2014 Ahhh right... well lambda there if you need it.... Sorry to spam but u dont have std rad kicking about do you? Ok cheers dude and afraid not pm'd I got the manifold gasket and lamda sensor with plug pm me s offer Pm me a price bud and will let you know Link to post Share on other sites
fremyjay Posted July 28, 2014 Author Share Posted July 28, 2014 ^^^ Link to post Share on other sites
akyakapotter Posted July 29, 2014 Share Posted July 29, 2014 Friend of mine has a brand new td fuel pressure regulator never been fitted that he's looking to get rid of Link to post Share on other sites
fremyjay Posted July 29, 2014 Author Share Posted July 29, 2014 Im currently bidding on a sard one but if you pm me a price and i will let you know if it falls through bud Link to post Share on other sites
_shaun_ Posted July 29, 2014 Share Posted July 29, 2014 I've for a 98spec thermo housing minus the thermostat and big box of pipes am sure there will be a few is the one to water pipe. Link to post Share on other sites
fremyjay Posted July 30, 2014 Author Share Posted July 30, 2014 Surely someone has these bits lying about Link to post Share on other sites
corofin12345 Posted July 31, 2014 Share Posted July 31, 2014 well man, have alot of OEM parts here for sale.. pm me what ya need and ill see if i have them Link to post Share on other sites
TD04HYBRID Posted July 31, 2014 Share Posted July 31, 2014 I've got a set of driveshafts pm me a offer Link to post Share on other sites
fremyjay Posted July 31, 2014 Author Share Posted July 31, 2014 (edited) I have a set here but im missing the end that goes in the gearbox off one and need two outer boots, so trying to find which is cheaper, wether buying cv boots ect or buying a decent set of shafts, all the other parts i may have already but will let you know corofin, but if anyone can also help with a selection of nuts, jubilee clips and odd vacuum pipes ect from engine bay would be great Edited July 31, 2014 by fremyjay Link to post Share on other sites
TD04HYBRID Posted July 31, 2014 Share Posted July 31, 2014 I have a set here but im missing the end that goes in the gearbox off one and need two outer boots, so trying to find which is cheaper, wether buying cv boots ect or buying a decent set of shafts, all the other parts i may have already but will let you know corofin, but if anyone can also help with a selection of nuts, jubilee clips and odd vacuum pipes ect from engine bay would be great Bud PM me i have all standard hoses/blue vacuum piping. Great Condition Driveshafts ( got to be cheaper than buy all boots ect...) let me know Link to post Share on other sites
corofin12345 Posted July 31, 2014 Share Posted July 31, 2014 I have a set here but im missing the end that goes in the gearbox off one and need two outer boots, so trying to find which is cheaper, wether buying cv boots ect or buying a decent set of shafts, all the other parts i may have already but will let you know corofin, but if anyone can also help with a selection of nuts, jubilee clips and odd vacuum pipes ect from engine bay would be great should have all that here too, have a full car for breaking, also have inner CV cups.... its pretty much stripped to the ground now.. shed full of OEM parts Link to post Share on other sites
