Anybody give some feedback on it taking her easy till it gets mapped no boosting over stock boost :(
Edited by Gainzy
Haha, now thatll sort you out.
just so u know u literally need a quarter of one, its more han enough........
yeah keep it below 3-4k when possible and dont load it to bad
It drives spot onif I take half I'll blow myself to piece's lol a plug n play will just make it run rich TD should do finance haha
Edited by Gainzy
My fuel filter has been leaking abit I have ordered another one I have thin white smoke coming out the exhaust when warm and gets heavy slowing down from 70 to 30ish I expect it due to the fueling with ot running stock ecu my water coolant seems fine can't really think what else it can be other than condensation maybe trapped and over fuel...
Think my head gasket or stem seals have give up it smokes white when warmed up slowing down I have just had a new rebuilt turbo fitted so I hope it's not that smoke's an absolute ball ache as it could be anything it drives spot on though grrrr
Yes, gunna have to take it off I reckon and have a look almost giving up now :(
before taking it of do all the basic checks... its just been rebuilt so surely cant be that..
have you got a video? as if its only a thin layer be condensation..
going to say head gasket i think
tbh even if its not mapped it should be ok on stock ecu/map
mine ran perfect for ages on stock ecu and no map with the same mods you have on my GT
only smoked heavy when it blew up-turbo
Edited by iamlegend
Is the smoke defo white ? Then its water, turbo, condensation in exhaust or coolant in the combustion chamber.
Are the water & vacuum lines on correctly on the inlet ? Putting these on wrong will make it burn water and produce white smoke.
Id run it for a few miles to try and clear any condensation in the exhaust. Take water lines off the turbo. Do a sniff test for HG failure.
I'm going to take it all apart again the joys! I'm running all stock so it's not that I could even give it a good boost run been bound to 3000 revs, thanks for the input Ash it will get to TD one day lol
Yes definately white I did have the throttle body off see I've known a few k1's not use waterline's but I'm using them! I've ran it in quite abit now say 100 mile's my fuel filter was leaking ordered a new one thanks
If it was turbo or stem seals would it not be gushing white smoke at a stand still I can literally drive a good mile boosting abit and the smoke won't be present till the cars well warmed up a little will come out from a stand still but most come's out when driving :-/
Depends on how bad it is but yeah, stem seals its blue smoke on first start up, turbo its normally blue smoke on over run or at idle, can get a bit whilst boosting aswell. PCV valve being fucked can give smoke off on boost aswell but again that would be blue smoke.
Id get someone to follow you and then tell you when exactly its smoking.
Thanks for the help it's going to the garage for a good check over it's annoying as fook everyone is dying behind me so I've stopped driving it I need to know what the bloody hell it is,it's starting to be money money money rather than fun fun fun :(
Check vacuum pipes a d water pipes are connected properly
any other signs that hg has gone.
does it pressurise ?
It all seems to drive spot on had a quick look at the pipe's before can't see anything wrong I hope it's something simple as I say it's smoking at it's worst braking from 70 to 60 then putting my foot down again around 4,000 revs it goes away then come's back
