Changed my engine loom over and it went straight forward.
After I changed the loom the fuel pump and ignition has stopped working. It turns over and I'm getting power to everything.
Any help welcome as it's confusing the feck out of me
  • 5 months later...
Assuming there isn't a power feed issue and the ecu and open circuit relay are actually getting power - The fuel pump and ignition are triggered from ecu which only runs them when it receives a signal that the engine is rotating from the cam angle sensor inside the dizzy. If the ecu isn't getting a signal then neither the fuel pump nor the ignition outputs will trigger. I'd make sure your pins to the dizzy are the right way around. As a test you can take the dizzy out and manually spin it by hand - you should hear the pump trigger and the injectors clicking.
Edited by Stu
