iamlegend Posted September 1, 2014 Posted September 1, 2014 will this cause any problems do you think?? tiny little chips on the disc my new discs turned up like this Quote
Gainzy Posted September 1, 2014 Posted September 1, 2014 I would send them back it's damaged goods Quote
akyakapotter Posted September 1, 2014 Posted September 1, 2014 I'd sent them back also could cause uneven wear on the pads. Quote
mikey4410 Posted September 1, 2014 Posted September 1, 2014 Its not acceptable dude. They should be perfectly flat and as a above cause issues. Not good Quote
DevonGT Posted September 1, 2014 Posted September 1, 2014 Definately send them back, that's not what you payed for. Quote
Keri-WMS Posted September 1, 2014 Posted September 1, 2014 Those are small voids in the casting - the place that made them should have used a thicker casting to make sure the surface is fully skimmed off. Should be safe to use but not very nice to look at! Quote
Starlet__SR Posted September 1, 2014 Posted September 1, 2014 Cheap casting, those voids could potentially turn into fractures under heavy use. Especially if there's moreDay Quote
iamlegend Posted September 2, 2014 Author Posted September 2, 2014 cheers chaps it was the caliper even thow wrapped up smashing of the discs sent the lot back! Quote
