Basically just changed the rear engine mount on my ep91 n/a for a polybush i had lying around....vibration, too much vibration through the cabin
best alternative to stock bush but with a little less vibration ? anyone ?
Have seen the trd set but i have a oem lsd box which i intend to fit soon and i cant find the oem lsd trd engine mount set
The TRD ones are all gonna be the same age as starlets near enough, unless people bought spares. I wouldn't waste the money on them. Poly mounts can be very shakey at idle, could try raise / lower the idle and see if its any better ?
Hopefully Jezza gets these poly mounts made up soon :)
oh, forgot to mention..i only changed the rear at the time and do have the other two, will replacing the other improve it overall ?
looks like the other 2 standard are taking all the vibration now lol
  • 3 weeks later...
