mr_K Posted September 16, 2014 Share Posted September 16, 2014 Last night I replaced the ewg spring with a 0.8 one but when I took it out for a test drive it was running only 0.3bar.Can there be a boost leak somewhere?My setup is a td04 wepr drag kit with a front mount intercooler setup on a forged engine.And the idle is always at 1100-1200rpms can a leak cause it to idle high?Thanks Quote Link to post Share on other sites
5e colin Posted September 16, 2014 Share Posted September 16, 2014 sounds like the rubber seal/flap isnt air tight after re-installing take the ewg appart again and recheck it Quote Link to post Share on other sites
5e colin Posted September 16, 2014 Share Posted September 16, 2014 high idle can be a vac leak on the inlet manni check them al there Quote Link to post Share on other sites
mr_K Posted September 16, 2014 Author Share Posted September 16, 2014 Ive checked all the vacuum pipes all seem to be in place only thing that confuses me is the two breather nipples on the steering rack are open.Does that affect anything got to do with steering? Quote Link to post Share on other sites
mr_K Posted September 16, 2014 Author Share Posted September 16, 2014 Ive checked all the vacuum pipes all seem to be in place only thing that confuses me is the two breather nipples on the steering rack are open.Does that affect anything got to do with steering?Ive checked all the vacuum pipes all seem to be in place only thing that confuses me is the two breather nipples on the steering rack are open.Does that affect anything got to do with steering? Quote Link to post Share on other sites
daniel_g Posted September 16, 2014 Share Posted September 16, 2014 Sounds like the EWG hasnt sealed right since its been stripped down.And the vac lines that go to the rack are to raise the idle when the car is under load, say at full lock with all the lights on. Wont do it any harm with no vac going to the rack. Quote Link to post Share on other sites
mr_K Posted September 16, 2014 Author Share Posted September 16, 2014 You see on the ewg there is two nipples im using the lower one and the top one I took it off completely. Will this be a problem. Quote Link to post Share on other sites
ROTABOOST Posted September 17, 2014 Share Posted September 17, 2014 No that's the right way to run the wastegate if you are running WG spring pressure. As above id check the diaphragm is sealed and not pinched on the WG Quote Link to post Share on other sites
mr_K Posted September 17, 2014 Author Share Posted September 17, 2014 Thats what im gonna do today, need to take it off and check the diaphragm. Quote Link to post Share on other sites
mr_K Posted September 19, 2014 Author Share Posted September 19, 2014 Just an update..I took the wastegate off opened it up taken the diaphragm off and there is no cuts, I then re tightened all the intercooler clamps then took the car for a test drive the boosts gone up to 0.4 now. Quote Link to post Share on other sites
5e colin Posted September 19, 2014 Share Posted September 19, 2014 did you take the external gate of the manifold ???? if so u might have forgotten to refit the seat/ring for the valve ???? Quote Link to post Share on other sites
mr_K Posted September 19, 2014 Author Share Posted September 19, 2014 Nope I put everything back on im sure.There must be a air leak somewhere but its a very hard one Quote Link to post Share on other sites
Ollieh17 Posted September 19, 2014 Share Posted September 19, 2014 I found without a sealing ring you'd get no boost at all! And you'd hear the exhasut gas leakage. Is the turbo laggier than normal? Also is the any funny noises when turbo is boosting?Could be the spring is shit? Have you tried it with the old one back in? Quote Link to post Share on other sites
mr_K Posted September 19, 2014 Author Share Posted September 19, 2014 Yes the turbo is very laggy in second gear onwards and no funny noises.Also just when its about to spool up the car feels hesitant. Im driving the car on the low boost button activated will that cause a problem? Its bypassed already Quote Link to post Share on other sites
Ollieh17 Posted September 19, 2014 Share Posted September 19, 2014 Shouldn't make a difference if its bypassed. I had a similar issue where my turbo wouldnt boost over 0.1bar spent ages checking things, turned out turbo was knackered.Have you checked the weld on the wastegate penny? Quote Link to post Share on other sites
mr_K Posted September 19, 2014 Author Share Posted September 19, 2014 Im sure the turbo is in good condition I bought it 3months ago off a clean subaru.My last suspicions are the penny too. Im going to have to remove the decat and check the penny when im off from work and have time. Quote Link to post Share on other sites
ROTABOOST Posted September 19, 2014 Share Posted September 19, 2014 Why did you change the WG spring in the first place? Is it an ebay/cheap WG? I had one with a "1bar" spring and it would only make .4. I learnt my lesson and have switched to a turbosmart now, actually get a bar with a 1 bar spring now lol Quote Link to post Share on other sites
mr_K Posted September 19, 2014 Author Share Posted September 19, 2014 It had a wrong spring in it then I replaced it with the orginal one which was a 0.8bar and the wastegate is a tial one. Quote Link to post Share on other sites
