_shaun_ Posted September 24, 2014 Posted September 24, 2014 I've taken off my lower arms to be powder coated and gonna then poly bush it all but wondering if its with grabbing poly bushes for the stock front arb and for some reason I have it in my head the white line drop links don't fit with a oem arb is the right?Cheers shaun Quote
steviet Posted September 24, 2014 Posted September 24, 2014 Yeah think droplinks are different been looking at them too. Oem fix with nuts into bottom arms and have a ball joint at the arb. Were whiteline ones look to be just a threaded bar with nuts at either end. Think idworkz or like wise could comfirm that for you pal. Quote
Idrees Posted September 24, 2014 Posted September 24, 2014 Yes that's right, the Whiteline drop links fit Whiteline ARBs and stock ARBs on UK Spec and early EP82s only. Quote
morgey Posted September 24, 2014 Posted September 24, 2014 The D bushings are worth polybushing i found. Preferred the stock arb poly bushed than the whiteline 24mm one. And yeah theres 2 different arb droplinks but the mount onto the wishbone can be poly bushed even with the ball joint style version. Just need to find someone else who would want the other half of your set lol Quote
Ollieh17 Posted January 4, 2015 Posted January 4, 2015 Where can you get new droplinks for a glanza? Quote
5e colin Posted January 5, 2015 Posted January 5, 2015 ^^^^ if there the same as on my 95 gt then the 1s from a volvo fit there cheap to Quote
Ollieh17 Posted January 5, 2015 Posted January 5, 2015 Found them on camskill, 27 posted. What volvo colin? Quote
5e colin Posted January 5, 2015 Posted January 5, 2015 sorry i ment saaaab ollie http://www.ebay.co.uk/itm/2-x-Saab-9-3-1998-03-Stabiliser-Bar-Drop-Links-Front-/290599273931?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Car+Make%3ASaab%7CModel%3A900&hash=item43a91105cb 11.50£ delivered for 2 :) Quote
Djaniero Posted September 8, 2019 Posted September 8, 2019 Thread revival! @5e colin did you any issues fitting these? I bought some via the link above a couple of months back, but only got around to fitting them yesterday. The bolt on the Saab rods were too big to attach to my roll bar...gutted Quote
Gary91 Posted September 9, 2019 Posted September 9, 2019 I believe you need to drill out the hole on the roll bar Quote
Djaniero Posted September 9, 2019 Posted September 9, 2019 Stupid question, but is that safe to do? Quote
Djaniero Posted September 10, 2019 Posted September 10, 2019 9 hours ago, Gary91 said: Yes. Also, found the original post 9 hours ago, Gary91 said: Thanks man😎 Quote
5e colin Posted September 28, 2019 Posted September 28, 2019 Yes safe to do measure the size of the link for the size of drill it you nead still on the car right now last long and no isseus as of now Sorry for late reply alway working these days not much time to be online Quote
