Go for a 215mm mr2 clutch if your replacing a standard one. Holds up to 220 (1 bar td04) and fits onto flywheel perfectly. Will need a small grind on pressure plate so it avoids the bellhousing ;)
Richard im running 230bhp and have access to lathes at work but would a standard clutch not be alright? Mines been fine up to now (ubtil i let the missus go for a drive and she booted it in 4th with clutch half down. I was like arghhh! Now it slips slightly
One of the lads is running 220 on the mr2 clutch and used it for 1/4 mile 3 or 4 weekends with no slips so depending on your torque it could hold perfectly. No the standard ones seem to go after about 180..
Don't need a lathe really because your not taking that much off but it would be handy to balance! Also it costs less that 100 lol
Hmmmm, not sure what clutch i have then. Its stopped slipping now somehow. 2 days ago i would boot it in 3rd and revs would pop up to 5k then drop to 4.5k then climb again.
Stopped doing it now though but might start again.
Doesnt feel like a paddle clutch, it comes in pretty smoothly
