drongo boi Posted October 16, 2014 Share Posted October 16, 2014 As above :-) Quote Link to post Share on other sites
Socks Posted October 16, 2014 Share Posted October 16, 2014 dizzy wont work.. the leads are same, however the turbo versions use a king lead... unless u mean to turbo a 4efe... in which case yes they will... Quote Link to post Share on other sites
drongo boi Posted October 16, 2014 Author Share Posted October 16, 2014 Yeh turbo 4efe :-) cheers dude Quote Link to post Share on other sites
jimlols Posted October 16, 2014 Share Posted October 16, 2014 Works fine on a 4EFE with a turbo bolted on, though you will need a way to retard it ideally and we haven't yet managed to get our emanage working on ours (More due to lack of time after simply wiring it in didn't work) Quote Link to post Share on other sites
5e colin Posted October 16, 2014 Share Posted October 16, 2014 works fine till a set bhp because of the midget internal coil loosing its spark after it Quote Link to post Share on other sites
Rob H@RCH Engineering Posted October 16, 2014 Share Posted October 16, 2014 It will work fine if anything its a better more modern set up than the fte set up as for it been a smaller coil and less power id say that was bolax as I run more boost on my first boosted fe set up than the fte runs and I was running a blitz K24 set up. The fe leads are different to the turbo ones as there longer due to the dissy been biger/longer some of the after market fte leads do fit but sum are too short to fit. Quote Link to post Share on other sites
drongo boi Posted October 17, 2014 Author Share Posted October 17, 2014 Mint cheers for the advice lads :-) Quote Link to post Share on other sites
