I had a civic radiator installed in my glanza.. normal sice is 42mm core i think but i ordered the 56mm.
now the engine is not heating as it should and while cruising it stays few millimetres above the C (cold). it only reaches the exact temp if i let it idle for 10min or so ..
should i worry or can i do something to arrange it without changing yhe radiator? maybe thermostat opens later or something?
i had the same on my mitsumitshi rad i had to blank 50% of my rad in winter time or it wouldnt warm attal even with 50% covered it would just be under normal temps !!!!!
there a big bollox on a road car i fitted a oem civic 1 now with no isseus
it probly wont make a diference lads i changed my thermostat to back then and it made no difference on the gauge only went back to normal with a single core
Thats what im thinkin as the problem started with the changing of radiator. but i can take a look to the thermo aswell
