Ethanep82 Posted November 17, 2014 Posted November 17, 2014 Anyone running one? What are they like etc? Looking to get one for td04, will this run well on td04 at say hopefully 1 bar? Any other info on these will be great, thanks Quote
Gainzy Posted November 17, 2014 Posted November 17, 2014 Meant to be a great ecu never had one you will benefit more from an emb all plug and plays are pretty much designed for ct9/hybrid but are known to fuel bigger turbo's it's pot luck weather they run top notch or not Quote
5e colin Posted November 17, 2014 Posted November 17, 2014 i had 1 for ages there the best ecu for a gt in my eyes they have a VERY agressive map on them they go like stink Quote
daniel_g Posted November 17, 2014 Posted November 17, 2014 Had one in my old GT, ran it at TD04 @ 1.1 / 1.2 bar. Was fast as fuck till it shat a rod lol. Quote
Ethanep82 Posted November 17, 2014 Author Posted November 17, 2014 Sounds good! But are you saying it would be better if I got an EMB instead? Quote
Ollieh17 Posted November 17, 2014 Posted November 17, 2014 Have heard a few cases of mines and blowing engines Quote
5e colin Posted November 17, 2014 Posted November 17, 2014 Have heard a few cases of mines and blowing enginesHave heard a few cases of mines and blowing engines i know why its becouse they run silly amount of timing :) and unchecked can blow your engine , usually because the engine is going to aint set to 10degree of timing and has underlying isseus Quote
daniel_g Posted November 17, 2014 Posted November 17, 2014 Sounds good! But are you saying it would be better if I got an EMB instead?Yes Quote
Gainzy Posted November 17, 2014 Posted November 17, 2014 Sounds good! But are you saying it would be better if I got an EMB instead?I would, but as for plug n plays Mine's and Blitz seem to have the better results with the emb you get your own custom map Quote
Ethanep82 Posted November 17, 2014 Author Posted November 17, 2014 I would, but as for plug n plays Mine's and Blitz seem to have the better results with the emb you get your own custom map Ah I see, Thanks for that, I'll save my money and go EMB then! Quote
ramses Posted November 17, 2014 Posted November 17, 2014 If you can map yourself ...i can say yes go for an emb .if you canot do this ,these ecus are very good... Quote
fiddlersport Posted November 18, 2014 Posted November 18, 2014 them mines ecu are popular for blowing engines, wouldnt blame the ecu but more like the engine cannot hold what the ecu is telling it to do maybe ? Quote
ramses Posted November 19, 2014 Posted November 19, 2014 (edited) them mines ecu are popular for blowing engines, wouldnt blame the ecu but more like the engine cannot hold what the ecu is telling it to do maybe ?Some engines and set up are so different... with a pnp ecu you always need a wideband after 0.8b. About timing ,they can alter better than the stock ecu meanwhile their iginition map are agressive on low octane Edited November 19, 2014 by ramses Quote
