dangeestarlet Posted November 17, 2014 Posted November 17, 2014 i can buy a glanza rolling shell but would want to put a n/a engine it it and run as a non turbo for the mrs,can it be done using the turbo loom? i know id have to use n/a shafts and exhaust etc but just wondering about loom , thanks Quote
5e colin Posted November 17, 2014 Posted November 17, 2014 yes you can i just passed nct like that not long ago just fit al turbo stuff from electronics and put on a turbo delete kit you will need to use a 4efte cat to pas emissions my readings where 0.05 on emissions Quote
dangeestarlet Posted November 17, 2014 Author Posted November 17, 2014 So I can put a n/a engine with no turbo into a glanza using the glanza v loom and it will run fine? Quote
5e colin Posted November 17, 2014 Posted November 17, 2014 yes it will easyest option is to use turbo exhuast system stock cat and get a smokey ct9 take proppeler out weld up the hole refitit with ct9 manni and put a blanking bolt in the oil feed and loop water lines thats exactly how i passed because my turbo was smokey and didnt have a spare ct9 Quote
daniel_g Posted November 17, 2014 Posted November 17, 2014 Pretty easy buddy, im doing the same with a GT shell atm, put a N/a engine in it and using a EP85 ancillary loom i had, that plugged into the existing GT fusebox.There will be a few ways to do this just like turboing a N/a.The EP91 might be slightly different, i dont know if the ancillary loom disconnects from the fusebox like a EP82 does ?Worst case is fit a EP91 N/a full bay loom in the Glanza, use one from the same year for ease ie 97 loom in a 97 shell. The alternator, starter etc all use the same plugs. You need a N/a MAP sensor and ignition setup, the thermostat housing sensors may be slightly different depending on the year of the engine. And obviously a N/a ECU. Quote
daniel_g Posted November 17, 2014 Posted November 17, 2014 Havent spent a great deal of time on it only a couple of afternoons Quote
dangeestarlet Posted November 17, 2014 Author Posted November 17, 2014 Lovely, was hoping it would be easy enough , but the problem I got is it's very hard to find a n/a engine loom as hardly anyone breaks them lol, I can pick the glanza up very cheap and chuck a £100 n/a engine in and I got a cheap runaround Quote
5e colin Posted November 17, 2014 Posted November 17, 2014 yes indeed have everything from 4efte al electronics and sensors and injectors just slap a 4efe inthere and if you want to pass emissions you will need to use the 4efte cat this way if you ever want to turbo u just need to slap a turbo on or fit 4efte you will need to use the turbo map sensor !!! aslong as the map doesnt see boost if feuls like an NA Quote
dangeestarlet Posted November 17, 2014 Author Posted November 17, 2014 Thanks Colin helps allot Quote
littlegreenmonster Posted November 23, 2014 Posted November 23, 2014 As we speak dangee im pulling out my na engine and loom to do a turbo conversion :') want the loom when im all done ?? Quote
richardc9052 Posted November 23, 2014 Posted November 23, 2014 No need to change the loom.. the best combination for n/a power i found is a turbo loom with an n/a engine. You can just use a uk n/a exhaust with cat and that will pass emissions Quote
daniel_g Posted November 23, 2014 Posted November 23, 2014 No need to change the loom.. the best combination for n/a power i found is a turbo loom with an n/a engine. You can just use a uk n/a exhaust with cat and that will pass emissionsWhat ignition system do you run with this, a turbo one ? Quote
