Sefton-EP91 Posted November 29, 2014 Posted November 29, 2014 (edited) I have a HKS SSQV at the moment but was looking at getting the tial sport q. My question is. what pressure do I go for? 6, 8, 10 or 11 Psi?I will be at 1.4bar+ on a WEPR Billet td04 hybrid turbo. Thanks for all advice in advance Edited November 29, 2014 by Sefton-EP91 Quote
maddox710 Posted November 29, 2014 Posted November 29, 2014 What ever you want really the spring will hold it to the designated pressure or near enough anyway. so say if it's a 1 bar spring and your driving around upto around 14 psi or so it won't dump fully will flutter Quote
daniel_g Posted November 29, 2014 Posted November 29, 2014 Id go for a fairly stiff spring in it, BOVs can be annoying going off every two seconds at the slightest hint of boost. Stiff spring and it will only dump when youre banging along at full chat.Depends on what you like though Quote
maddox710 Posted November 29, 2014 Posted November 29, 2014 Id go for a fairly stiff spring in it, BOVs can be annoying going off every two seconds at the slightest hint of boost. Stiff spring and it will only dump when youre banging along at full chat.Depends on what you like though Cho cho choooo Quote
Sefton-EP91 Posted November 29, 2014 Author Posted November 29, 2014 Right I see, I kind of understood it but not 100% lol thanks guys for your help! I will go for a stiffer spring then, I'm not a big fan of the sound of bov's, love the flutter noise! LolThanks again guys Quote
daniel_g Posted November 29, 2014 Posted November 29, 2014 Cho cho chooooHaha MCM GT chooo choooRight I see, I kind of understood it but not 100% lol thanks guys for your help! I will go for a stiffer spring then, I'm not a big fan of the sound of bov's, love the flutter noise! LolThanks again guys Yeah man having an adjustable BOV or one with different springs is the best of both worlds. Ive go no BOV on mine so it just flutters but i do miss the dump valve noise. Quote
Rob H@RCH Engineering Posted November 29, 2014 Posted November 29, 2014 The spring pressure is nothing to do with the amount of boost you run, the spring rate is more down to the vacume pressure that opens it, a soft spring will open sooner as it needs les vac to open it a hard spring will open later. I run the softest spring in my tial shimmed up with washers to get it how I like it. Quote
Sefton-EP91 Posted November 29, 2014 Author Posted November 29, 2014 Thanks rob! Yeh i guessed it was how soon it opens! Quote
