Pauly ep82 Posted December 13, 2014 Posted December 13, 2014 Is it possible to convert an ep82 to 4wd so I can take loadsa power? If it is a rough guide/parts I need will help.Thanks a lot for your help comments Quote
daniel_g Posted December 13, 2014 Posted December 13, 2014 A grinder would be a good start. To cunt the starlet up for a transmission tunnel and cunt everything away you dont need.Can you weld ? You'll need to add loads of beams for strength.Then choose a donor car. A Lamborghini Gallardo would be a good choice. Cheap to buy, easily available. Then simply take everything out the lambo and fit it in the starlet. Shouldnt take too long. Then start it up and away you go.. !!! : Quote
TurboTobz Posted December 13, 2014 Posted December 13, 2014 Daniels advise is very much the way to go. You should get an electric supercharger kit on ebay Quote
_shaun_ Posted December 13, 2014 Posted December 13, 2014 Also If you fit an electric supercharger its theN Classed as a hybrid so cheaper road tax y0. Quote
richglanzav Posted December 13, 2014 Posted December 13, 2014 mate check my build thread - 6wd corolla conversion - 600whp and 10 sec dead quarter mile. but seriously dude this is the most covered question on the entire forum hence the sarcastic replies lol. dont look to convert a starlet turbo to 4wd...what you need to do is to swap the turbo engine into a 4wd starlet thats the way its done. Quote
