It's very time consuming. Just make sure your soldering skills are upto par before you start. Ive done small things like alarms and different wires and you can lose half a day just trying todo 2 wires. Be a lot easier with your engine out and ina proper garage tho
Lable every thing. Cut all out and re run the wires out of sight. It's a lot of work with lots of soldering but well worth the effort.
cut the connectors off? obviously not close to the connector then label that wire an go from there is what ya mean?
