Ollieh17 Posted December 29, 2014 Posted December 29, 2014 Engines out and all been tidied up and bay sprayed. Seems a shame to put the dirty wiring loom back in place. My plan is to remove the old conduit and tape. Just wondered if people have done this and what material they used? It cant be a solid loop as not planning on removing all the plugs. I have seen a wiring tape clothe that looks good? Anyone tried this stuff? Quote
_shaun_ Posted December 29, 2014 Posted December 29, 2014 I just used black electrical tape same as it comes wrapped in. You get some nice braided covers but would require the plugs to be removed Quote
Ollieh17 Posted December 29, 2014 Author Posted December 29, 2014 Yeh electricl tape isnt the best looking. This clothe tape is supposedly what they use on new cars, may give it a tryLink herehttp://pages.ebay.com/link/?nav=item.view&alt=web&id=221360583733 Quote
Whitenoize Posted December 29, 2014 Posted December 29, 2014 Boost junkies do kits of the conduit no need to take all the plugs of as the conduit splits down the middle Quote
_shaun_ Posted December 29, 2014 Posted December 29, 2014 Aye seen it on the inside of a lot of vag cars dunno how well it holds up in the engine bay. Think sadly wires are just doomed to be ugly. As I say the braided covers look realy nice but for the hassle of cutting and redoing plugs think just aswell doing a full wire tuck Quote
Ollieh17 Posted December 29, 2014 Author Posted December 29, 2014 Yeh would love braided covers but cba with the effort. Its not a show car, just want it to look quite nice. Quote
Ollieh17 Posted December 29, 2014 Author Posted December 29, 2014 May buy some conduit and some tape Quote
daniel_g Posted December 29, 2014 Posted December 29, 2014 I bought some black cloth tape on ebay and redone the injector wiring harness, its sticky on one side and obviously sticks to itself. Looks ok and quite subtle.Something like ebay number 111465794914 Quote
The Toffinator Posted December 29, 2014 Posted December 29, 2014 You can buy the wide Insulation tape, thats quite good and looks smooth Quote
Ollieh17 Posted December 29, 2014 Author Posted December 29, 2014 I bought some black cloth tape on ebay and redone the injector wiring harness, its sticky on one side and obviously sticks to itself. Looks ok and quite subtle.Something like ebay number 111465794914Yeh thats the stuff, maybe alright for small bits but thinking not so good for the main loom. Must be reaonsably again if they use it on new audis, jags etc Quote
daniel_g Posted December 29, 2014 Posted December 29, 2014 Ive seen it on almost every new-ish car there is.Seems ok stuff that i got but then again ita seen 0 miles so pretty unteasted hahaIf youre doing the full engine harness then the thicker width the better really. Quote
Ollieh17 Posted December 29, 2014 Author Posted December 29, 2014 On the main look to battery etc i will probably use normal insulation tape and conduit Quote
AdamB Posted December 29, 2014 Posted December 29, 2014 Conduit is good but don't buy the coloured stuff, ie blue or red as it fades and goes white with the heat in the engine bay, just stick to black. Quote
Ollieh17 Posted December 29, 2014 Author Posted December 29, 2014 Yeh only black rest looks takky! Any opinions on the tape? Quote
fiddlersport Posted December 29, 2014 Posted December 29, 2014 I used the proper wiring loom tape, its expensive but does a good Jobits called scapa Quote
TimD Posted December 30, 2014 Posted December 30, 2014 I used loom tape, looks ok. I wanted to remove all the plugs and sheaf it using the braided stuff, but figured for something that isn't seen it's not worth the risk of wiring up something the wrong way and introducing a short. Quote
fiddlersport Posted December 30, 2014 Posted December 30, 2014 insulation tape leaks the sticky shit after a while , any proper wiring loom tape will be good Quote
Ollieh17 Posted December 30, 2014 Author Posted December 30, 2014 I used insulation tape then going to go over it again in loom tape Quote
fordie_glanzaV Posted December 30, 2014 Posted December 30, 2014 I brought a roll of cloth loom tape from ebayItem no: 111465794914Used that tidying mine up. Seems alright so far... Quote
Ollieh17 Posted December 30, 2014 Author Posted December 30, 2014 Worth taking all the insulation tape off and doing it in the tes stuff? Have some on the way Quote
fordie_glanzaV Posted December 30, 2014 Posted December 30, 2014 Id gone over the top of some old insulation tape. And stuck fine.. So far havent been able to fault it. Quote
