I bought a braided clutch line from Hel. Advertised to go from master cylinder to slave cylinder. I donthave anslave cylinder atm so can't properly test fit. But this line doesnt look like it will attach to the slave cylinder?
0B55002E-F649-4895-8688-48A4470752F6_zps
It looks like the L shaped end will go into the slave cylinder, will have to check whether its the right thread size.
Edited by 5T4R7ET N/A
From HELs description, it was meant to go from master cylinder to slave. Which in my view would remove all the hardlines? This is is the slightly more expensive line than the common ones
£29.99, no where seems to show the right picture for the line they are selling its very annoying.i threw the hardlines so pretty fooked lol
The line you bought above advertised to go from master cylinder to slave cylinder looks wrong, the 90° male end will most likely fit the slave cylinder but the but the female end is the wrong fitting for the master cylinder. This line also looks too short to run from master cylinder to slave cylinder.
However....over the gearbox the clutch line transitions from solid hose to rubber hose, the fitting you have above should connect into the male fitting on the solid hose where the line changes from solid to rubber, eliminating the rubber hose and the solid hose running over the gearbox to the slave cylinder.
Pete
