sosolid Posted January 19, 2015 Posted January 19, 2015 how easy isit to reseal the sump and is there anything to look out for when doing it? also what type of sealant do people use? Quote
daniel_g Posted January 19, 2015 Posted January 19, 2015 Just make sure the sump is totally straight and clean, and that all the old sealer off the block is gone.I used this stuff its awesome Quote
Liam_D Posted January 19, 2015 Posted January 19, 2015 Vw sump sealant is the best stuff I've used. Quote
sosolid Posted January 20, 2015 Author Posted January 20, 2015 (edited) is the vw selant called Dirko Elring? also is the sump on the glanza aluminum? also you don't need to put sealant on the block, just the sump right? Edited January 20, 2015 by sosolid Quote
fiddlersport Posted January 20, 2015 Posted January 20, 2015 prick stick ! IF you on a budget ! Quote
fiddlersport Posted January 20, 2015 Posted January 20, 2015 too expensive to use on the sump ! how about double sided tape ? Quote
Calum122 Posted May 4, 2015 Posted May 4, 2015 Just make sure the sump is totally straight and clean, and that all the old sealer off the block is gone.I used this stuff its awesome Going on recommendation for this stuff. Quote
