Gainzy Posted February 8, 2015 Posted February 8, 2015 Full size radiator, anybody rate these? Sell them on Ebay. Quote
Phil Posted February 9, 2015 Posted February 9, 2015 personally id give one a go if it would fit with my turbo. but no, ive no first hand experience. Phil Quote
Gainzy Posted February 9, 2015 Author Posted February 9, 2015 I do like the half rads nice and neat but I like long thick rads with the shrouds still in place for the price of them could get a full triple core kit don't think they look as good though haha Quote
JayJ Posted February 9, 2015 Posted February 9, 2015 I run ebay half rad, it has kept the water inside so far Quote
Gainzy Posted February 9, 2015 Author Posted February 9, 2015 I run ebay half rad, it has kept the water inside so far My mates didn't like water in the end haha Quote
TimD Posted February 9, 2015 Posted February 9, 2015 I have one, works fine for me on track, would imagine it would be more than upto the job for a road car. Cant remember the make, they all probably come from the same factory. The cap that came with it wasn't much cop mind so I'd replace that. Quote
Gainzy Posted February 9, 2015 Author Posted February 9, 2015 I have one, works fine for me on track, would imagine it would be more than upto the job for a road car. Cant remember the make, they all probably come from the same factory. The cap that came with it wasn't much cop mind so I'd replace that.Was it this one matey?http://pages.ebay.com/link/?nav=item.view&id=201271424558&alt=webI have a genuine HKS cap should fit. Quote
WallaceGlanza Posted February 9, 2015 Posted February 9, 2015 I was using one too and worked perfectly. However if your hks cap is for the standard radiator it probably won't fit,the aftermarket radiators use a different type. Quote
TimD Posted February 9, 2015 Posted February 9, 2015 That looks like the one, I got mine for 90 i think. But it was an auction that ended at an odd time of the day. Quote
Gainzy Posted February 9, 2015 Author Posted February 9, 2015 That looks like the one, I got mine for 90 i think. But it was an auction that ended at an odd time of the day.What was the rad cap fitment.. Quote
WallaceGlanza Posted February 10, 2015 Posted February 10, 2015 Type S, I'm selling the genuine TRD cap I was using if you're interested. Quote
5e colin Posted February 10, 2015 Posted February 10, 2015 there to good for on the road they cool to much !!! i used to have a mitsumisho twin core rad i had al sorts of cooling isseus ( being to cold ) so swapped over to a small single core rad and is perfect again Quote
WallaceGlanza Posted February 10, 2015 Posted February 10, 2015 there to good for on the road they cool to much !!! i used to have a mitsumisho twin core rad i had al sorts of cooling isseus ( being to cold ) so swapped over to a small single core rad and is perfect again I had no problems on the road and through winter with a standard thermostat, measuring the temp with a defi gauge too. That was a 40mm thick but I think just single core one. Quote
scottieboi94 Posted February 10, 2015 Posted February 10, 2015 I had one but moved to a half rad due to space restrictions, its pretty restricted with a ct9 setup so if you go to a bigger setup you will want a half rad even more! Quote
Gainzy Posted February 10, 2015 Author Posted February 10, 2015 Heats the killer, mine works fine atm but it's off the non turbo ep91 I just have little worries running hybrid with it been thinner, the civic rads are the in thing easy to work with out the way neatness but they have no shroud and my cooling panel will have to go as it holds no purpose if I have the cash payday Lews SARD rad is mine lol Quote
TimD Posted February 10, 2015 Posted February 10, 2015 (edited) What do you use your car for? Track days? Drag Racing? Driving to the shops? Edited February 10, 2015 by TimD Quote
Gainzy Posted February 10, 2015 Author Posted February 10, 2015 What do you use your car for? Track days? Drag Racing? Driving to the shops?General driving atm be on track in the end when I get sorted! Quote
